Scratch Build – In Progress Al 26.982 -aluminium- scratch build
Discussion in 'Project Logs' started by pccustom, 12 Sep 2021.
  1. pccustom
    pccustom Multimodder
    12 Jul 2017
    top panel. I created two custom-made supports on which the radiator and relative fans will be installed, 3 incoming and 3 outgoing
    internal panel
    external panel
    These 2 panels for united support are very resistant and integral part of the structure
  2. pccustom
    12 Jul 2017
    thank you cablemod
  3. pccustom
    12 Jul 2017
    feet arrived a special thanks to Explore Modding
    inside led panel 3 parts.
    Cheapskate, Dot_Kappa and jones-965 like this.
  4. Cheapskate
    13 May 2007
    You resorted to getting parts milled?!?! Will there be earthquakes or will it rain frogs? :D
    pccustom and Dot_Kappa like this.
  5. pccustom
    12 Jul 2017
    I had to vary my original project that included 6 fans on the 360 or 3 radiator in incoming and 3 outgoing I leave the 3 entering this, because damaged the aesthetics of the case ..
    Under with photos ... Proceed with 2 acrylic panels, the front panel of the new Mac Pro, essentially are 2 overlapping panels with holes that alternate give this pleasant effect ..
    [VIDEO]
  6. pccustom
    12 Jul 2017
    Prepare the umbrella :)
  7. Cheapskate
    13 May 2007
    You sent out for more? :lol:
    Looking great.
  8. pccustom
    12 Jul 2017
    Conclusion of the complicated panel that welcomes the motherboard All cables and skirt if not structural part of the whole PC What I realize is an external panel that besides closing I will be in Leds essentially would have to come like this,
    the LEDs will then be put but this after painting These sibits the latest panels to make ...
    Structural panelpannello strutturale
    even here then LED will be positioned and a 2 mm additional panel with logos created
    This is the internal panel that welcomes the motherboard we mount everything.
  9. Cheapskate
    13 May 2007
    Love it! Not much aluminum for the title, though. :D
    pccustom likes this.
  10. pccustom
    12 Jul 2017
    look to the end it' will be appropriate..
  11. riekmaharg2
    riekmaharg2 has completed the PowerCore scratch build
    22 Feb 2009
    This build is coming along fast!, you've definitely got some serious patients drilling out all those holes
  12. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    I used to mod pretty hard back in the day...case mod after mod some times 2 and three going at the same time....... i did burn out..... i know you will too and it will be a sad day for modding.
    You keep old skool modding alive and for now i'm loving it :rock::rock::rock:
  13. pccustom
    12 Jul 2017
    Expansion PSU and shaping cover
    holes power and leds.
    Assembly ..
    to be continued...
  14. pccustom
    12 Jul 2017
    Creation of the tank that will be installed in the front,
    previously I had already cut the various layers of Plexiglass now it is Shapes glue and set up the holes for cooling tubes.
    It is hoped that it comes like this project ...
    Before closing hermetically ... test
    [VIDEO]
  15. pccustom
    12 Jul 2017
    all panels have been realized, It is time to fix pump position And where to fix the cables inside
  16. The_Crapman
    The_Crapman Don't phone it's just for fun. Lover of bit-tech
    5 Dec 2011
    I really like those cable combs
  17. Dot_Kappa
    Dot_Kappa 100% Puppet
    23 Mar 2006
    I fall in love with those cables holders :thumb:
    pccustom and The_Crapman like this.
  18. Cheapskate
    13 May 2007
    Brilliant!
    -Here I was about to toss aluminum picture frames. Now I might use them for cable combs... someday... maybe.
  19. pccustom
    12 Jul 2017
    And after unulmable color tests we are Painting ... It starts from the bottom and rear panels ....
  20. MADPC
    MADPC Minimodder
    10 May 2020
    I suspect this project will be great!!!
