Case Mod - Complete Al 26.982 -aluminium- scratch build
Discussion in 'Project Logs' started by pccustom, 12 Sep 2021.
  1. pccustom
    pccustom Multimodder
    12 Jul 2017
    back led panel complete
    [VIDEO]
  2. pccustom
    12 Jul 2017
    We begin to reassemble everything ..
    Halo Cooler Master fan paints. It was a real company since you can disassemble up to a certain point ...
    Assembly on the radiator
    Top panel assembly
    Taritha, 4LIEN and Dot_Kappa like this.
  3. pccustom
    12 Jul 2017
    dissassembling and painting rams
    Taritha and Cheapskate like this.
  4. pccustom
    12 Jul 2017
    Installation LEDs strips inside the panels
    Upper panels with fans mounted
    Taritha, Cheapskate, 4LIEN and 2 others like this.
  5. kim
    kim hardware addict
    10 Jan 2016
    Pure beauty that chassis:rock:
    pccustom likes this.
  6. Dot_Kappa
    Dot_Kappa 100% Puppet
    23 Mar 2006
    It looks like real aluminum :clap:
    Nice lighting :thumb:
  7. pccustom
    12 Jul 2017
    Seasonic GX 1000 power supply disassembly ... I could not leave it so ...
    I help label removal with a hair dryer.
    Reassembly
    come on ... let's see how it stands inside ....
  8. 4LIEN
    4LIEN Modder
    4 Jan 2020
    Great work! I love this silver finish! Look real!
  9. Cheapskate
    13 May 2007
    The case lit up is beautiful! :D
  10. pccustom
    12 Jul 2017
    Painting of the panels that will compose the large side cover panel in all are 5 parts First uello external panel with LED logo
    Assembly part of the remaining panel
    This panel is a little complex soon Leds insertion and test ..
    Cheapskate likes this.
  11. pccustom
    12 Jul 2017
    Front tank assembly, after being painted, grouted and repainted several times to eliminate any imperfections I assemble the front and rear covers to give it an elegant touch
    let's mount
  12. Cheapskate
    13 May 2007
    Lovely. :D Time to invest in a new sheet of cardboard.
    kim and pccustom like this.
  13. kim
    kim hardware addict
    10 Jan 2016
    The feet remind me of Oldnewby's case feet style :grin: ... this is a great modding session :thumb::dremel:; I really love your work and ideas, :clap:
  14. pccustom
    12 Jul 2017
    completion of the external side panel. leds and test insertion ..
    another panel overlaid with logo .. we hope we never have to disassemble it ...
  15. Cheapskate
    13 May 2007
    LOOOVELY :D
    I still don't see how you get the masking off without taking some paint free. I ALWAYS had problems.
    The_Crapman and pccustom like this.
  16. Vault-Tec
    30 Aug 2015
    You need to do it pretty soon after painting.
  17. pccustom
    12 Jul 2017
    I think it is important to treat the surface well before painting everything here, an alcohol to degrease, I have another problem instead, that is that when I remove the film there is some glue left when I use wd 40 to remove it and it does not damage the paint. ...
  18. The_Crapman
    5 Dec 2011
    That logo'd panel is so cool
  19. Cheapskate
    13 May 2007
    That I can answer: Naphtha / lighter fluid / BBQ starter. Put some on toilet paper and it melts the gum. It shouldn't damage dry paint either. (Tenants put duct tape in the strangest places...)
    -Just do it outdoors, and no smoking. :lol:
  20. pccustom
    12 Jul 2017
    it's time to set up the motherboard with all its components ie ram, ssd, and cpu waterblock
    in the video all steps ...
    [bbvideo]
