Case Mod - In Progress Alienware Aurora ALX-XL
Discussion in 'Project Logs' started by kier, 27 Oct 2012.
  1. kier
    kier -----------------
    1 Mar 2011
    The Alienware Aurora ALX-XL
    Sometimes you get a chance you can't say no to, so that's what happened to me.
    After some discussions and exchanging ideas with Dell, I am very happy to announce to you a build with a super case. It's allready beautiful But I'm gonna give it a try ;)
    The Alienware Aurora desktop.
    And not only the case, but a complete configuration with the following components:
    - CASE : Alienware Aurora ALX 875W-chassis (Matte Black)
    - PROCESSOR: Intel® Core i7-3820 (4 Core, 10MB Cache, 3.60GHz)
    - OPERATING SYSTEM : Windows® 7 Home Premium, 64-bits
    - GRAPHICS : 1 GB GDDR5 NVIDIA® GeForce® GTX 555
    - MEMORY : 16GB (4 x 4 GB) 1.600 MHz Quad Channel DDR3
    - HARD DRIVE : 256 GB SSD
    - OPTICAL DRIVE : 8X Blu-ray Disc-rw-station en 24x dvd+/-rw-station
    Before I start, first I want to thank all the great sponsors for making this build possible.
    Alienware, for the system.
    Nvidia to deliver GPU upgrade (more on this later)
    And EKWB for the watercooling components
    There will be a lot of pictures again in this build. What is new is that I now going to add videos, think this will be a nice addition.
    First contact with an alien:
    Always a great feeling to receive packages :) Once everything is dragged into the living room to have another great feeling ..... unboxing
    The Aurora is certainly well packed, they have given this some good thought.
    A box in a box
    Clips to unlock the cover
    Almost :eeek:
    :jawdrop: :jawdrop: :jawdrop:
    Nice shapes
    Front also beautiful and clean
    One touch on the Alien head and the panel slides down.
    If the PC is turned on and you activate the sliding panel, the lights which illuminate the optical drives will turn on
    Acrylic part what looks very nice ... especially when it is enlightened
    Power button
    Behind this is a pushpanel to the front I / O. containing
    (2x) Hi-Speed USB 2.0
    (1x) SuperSpeed USB 3.0
    (1x) Mic
    (1x) Headphone
    At the rear is the handle to unlock the side panel.
    Pull the last vent
    To unlock the sidepanel
    The PSU (Alienware™ 875-watt) is also swappable and modular
    Another great gadget is the enlightenment on the back. Activated with a push button.
    Also a great gadget is the Alienware Active Venting.
    Next box. With keyboard and other accessories
    The Alienware tactx keyboard with two-zone lighting setup
    The Alienware mousepad
    Some documents
    Drivers and utilities
    Cables
    And two Alienware 3D avatars
    Not finished yet ..... a monitor, the beautiful Alienware OPTX AW2310
    Specs:
    •Connections Dual-link DVI (with HDCP), HDMI, 4 x USB
    •Viewable Screen Size 23.5in
    •Maximum Resolution 1,920 x 1,080
    •Contrast ratio 80,000:1 (dynamic), static not quoted
    •Brightness 400cd/m2
    •Response time 3ms (grey-to-grey)
    Back to the Alienware Aurora .... the inside
    First looks without sidepanel
    And again a nice gadget: when the sidepanel is removed, the inside is illuminated without the power on.
    Powered by rechargeable batteries
    Very handy!!!
    The caps for the airflow and coverup are very nicely designed and printed
    Cap for the GPUs is rotatable and removable
    Beautiful swappable, tool-less and cable-free hard drive bays
    Also well thought about is the power suply for the side panel (Lights)
    On the side of the powersupply are contact points which provide this
    For now a Nvidia GTX555 is installed, but this will be exchanged for two Nvidia GTX680
    Cooler motherboard
    And the beautiful Alienware CPU cooler
    Personally I really like this one, so it stays in this build (perhaps modify)
    What cable management is concerned, everything is provided. But it looks a bit messy.
    This will be better ;)
    Module for lighting, fans and other applications
    This will be a lot of work, but a very exciting thing to do.
    The first change that I'm going to do is swap the Nvidia GTX555 for two GPUs Nvidia has sent me.
    Again thank you Nvidia
    For sending me two Nvidia GTX680's
    Engine Specs:
    - CUDA Cores: 1536
    - Base Clock: 1006
    - Boost Clock: 1058
    - Texture Fill Rate: 128.8
    - Memory Speed: 6.0 Gbps
    - Standard Memory Config: 2048MB
    - Memory Interface Width: 256-bit GDDR5
    - Memory Bandwidth (GB/sec): 192.2
    Unboxing again
    The beautiful GPU's
    with one Dual Link DVI-I, one Dual Link DVI-D, one HDMI and one DisplayPort
    And installed the new GPU's
  2. kier
    1 Mar 2011
    And now it is time for some modding :)
    First a window in the Alienware Aurora. And maybe two, one on both sides.
    But this is for later... first one.
    The sidepanel
    Contacts for lighting has to be kept in mind
    And the shapes / curves must be maintained
    Everything is pretty easy to disassemble. Black panel removed and drawn the line for cutting
    Disassambled the remaining parts
    RGB strip for color effects
    Detached the Acrylic carefully
    What's left...a piece of iron
    This is what we gonna use for cutting the window in the plastic panel
    After some sawing and filing
    Excess plastic also removed with my dremel to place the window (later)
    first fit
    Next step. We use the jigsaw
    Removed the reinforcement strip and drawned the hole slightly larger than the window in the plastic panel
    And saw it (and some filling of course)
    The points which seem to be thin will be reinforced
    Furthermore, it's still a strong frame
    And placed everything back. The gap inside between the plastic and iron needs to be filled
    And the window is almost finished
    A big start topic with a lot of pics and vids, but hope you like it.
    Until the next update!!!
    Grtz.
    Kier
  3. Gtek
    Gtek Doesn't raise the bar; he IS the bar.
    10 Oct 2009
    Nice kier, this will be epic :thumb:
  4. l3p
    l3p www.^.nl
    1 Nov 2010
    Really curious where this is going Richard :)
    Congrats on the cooperation with Dell and Nvidia!
  5. hangar_15
    hangar_15 What's a Dremel?
    3 Mar 2012
    Great start! :thumb:
  6. kier
    1 Mar 2011
    Thank you Gtek :thumb:
    Thanks Peter, im curious also ;)
    :rock::thumb:
  7. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    Looks great Kier!
  8. whyte
    whyte What's a Dremel?
    27 Mar 2012
    Wow! So cool already. Looking forward to seeing this. KayinBlack's log has been awesome, so these cases seem like they will yield some cool results.
  9. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    Careful what you do with that name, apparently it's a summoning spell.
    Great start, let me know if you run into any problems, I've got my Area-51 case able to do just about everything short of walk the dog now. I've been able to get the ESA working with third-party boards, as well as getting GPU clocks tied into the deal.
    When you get into cable management, have fun with that nightmare. Also, if you'll pull the PSU I can tell you if it's a straight swap with the 1100W Delta that came in mine. I can also show you where to get those dirt cheap, if need be.
  10. Jipa
    5 Feb 2004
    Oh gawd the metal parts of that case look so rubbish...
    Good luck with that one!
  11. Attila
    Attila still thinking....
    22 Feb 2008
    You're right! But kier will make them nice. ;)
    It's looking better already with that window cut. Good luck. :thumb:
  12. kier
    1 Mar 2011
    Thanks :thumb:
    Thanks for the tip, didnt saw KayinBlack build before... sorry Kayin ;)
    Hi KayinBlack thanks, your doing a superb job my friend subbed for sure. the PSU is fine for now but thanks. About the cables.....hmm the cables, dont want to think about now
    Thanks :thumb:
    Thank you Attila ;)
  13. nagyizom
    nagyizom Minimodder
    2 Jun 2008
    Pure awesomeness! I'm very excited about this mod. Sub'd inmediately :)
  14. [ZiiP] NaloaC
    [ZiiP] NaloaC Multimodder
    9 May 2008
    Huzzah! Another build by Kier to drool over :D
  15. alain-s
    alain-s Minimodder
    12 Jan 2011
    The design of the sidepanel is fit perfect with the case very nice Kier. Looking forward to the next update.
  16. Vetalar
    Vetalar *learning english*
    21 Jun 2011
    after hours of new XCOM i'll shoot it if it moves :)
    interesting mod! i'll watch!!!
  17. kier
    1 Mar 2011
    Thanks :rock:
    After this on vacation ;)
    Thanks Alain :thumb:
    Shoot my Alien ???
  18. Vetalar
    21 Jun 2011
    yeah!!! with my trusty heavy plasma :D
  19. Guest-23315
    Guest-23315 Guest
    Definitely looking forwards to this!
  20. kier
    1 Mar 2011
    :eeek: :eeek: :eeek:
    Thanks :thumb:
