Hi guys, I have a predator 2.1 case (black interior) that Ive been meaning to do something with it for quite awhile. I've decided to add active vents to the top of the case like the newer models. Physically its possible I believe with some modding as the Predator case is 9.97" wide while the new ALX cases with the vents are 10.9". Seems like Id have to file dame the edges so it can sit flush with the case. Ideally in a perfect world I'd like to be able to get CC to work with it to move the vents automatically. Now heres a link to the vents: http://www.ebay.com/itm/Dell-Alienwa...ht_2710wt_1154 And heres a link to the MIO board: http://www.ebay.com/itm/190649063526...ht_1849wt_1154 I plan on using an Asus ROG board, do you think its possible to get it working since the hardwares there?
http://forums.bit-tech.net/showthread.php?t=228556 A thread discussing how to set up the vents you are talking about using an arduino system EDIT: Also your links dont work as the listings on ebay have ended.
