Hardware All About Ivy Bridge
Discussion in 'Article Discussion' started by arcticstoat, 10 Oct 2011.
  1. Ajhayter
    Ajhayter What's a Dremel?
    10 May 2010
    All seems excellent to me.
    I'm particularly excited about manually adjusting the multiplier from within Windows, not from an overclocking standpoint, but an underclocking standpoint.
    I can finally clock the CPU right down when I'm just browsing the web, saving on power and heat!
  2. Landy_Ed
    Landy_Ed Combat Novice
    6 May 2009
  3. GreekUser
    GreekUser What's a Dremel?
    13 Oct 2011
    The questions:
    Same amount of electrons move at smaller amount of space creating the same amount of heat as before. How about overheating?
    If the total length remains 22nm, 3D or 2D, were does the efficiency advantage comes from? Yes it's smaller, but it moves the same amount of electrons doesn't it?
  4. bobwya
    bobwya Custom PC Migrant
    3 May 2009
    I am in the market for a Ivy Bridge board for a 24/7 Super-NAS. Personally I need a board with a full PCIe 16x slot for a super-beefy multiport SATA card. AMD's Fusion chipset only has a PCIe 4x slot which doesn't cut the mustard :) I need that uber-low power consumption as well!!
  5. SpAceman
    SpAceman What's a Dremel?
    1 Nov 2010
    There is actually less electrons as the smaller transistors need less power to operate.
    It is more efficient because the 3D nature of the transistor means there is a larger surface area the gate is in contact with the silicon substrate. This means the transistors require a lower voltage to switch on and switch on faster when a voltage similar to levels used by the older 32nm planar transistors is used
  6. reneeculver
    reneeculver What's a Dremel?
    21 Oct 2011
    I'm happy to see that Ivy Bridge will have the same protection system that the Vax had in 1977.
    Renee
  7. Treacle
    Treacle What's a Dremel?
    4 Feb 2012
    Sandy Bridge CPU multiplier is limited to 63x, it's the BIOS that sets the lower limit in the 50's. IIRC the highest I've seen SNB verified is 59x.
Tags: Add Tags
