Windows All downloads corrupt =/
Discussion in 'Software' started by orb, 31 May 2005.
  1. orb
    orb satisfying.
    23 Dec 2003
    Everytime i try to download a big file, winRAR/WinZip always says its corrupt and never lets me extract anymore :blah: . I reformatted today because of this problem, thinking it may be caused with a fragged hard drive or something. This is not the case so i downloaded the same file i was trying to download before, (l2.c3.installer) and its corrupt and even the c2 one is corrupt :confused: .
    Does anyone have any ideas on what to do? I doubt the files are corrupt cause there from the offical website... And i cant really do much when any file over 50 + mb gets corrupt can i?
    Any ideas is welcome
    WinRAR Error: ! C:\Documents and Settings\Stroke\My Documents\L2_C3_Installer.zip: CRC failed in L2_C3_Installer\data2.cab. The file is corrupt
    WinZip Error:testing: L2_C3_Installer\ OK
    testing: L2_C3_Installer\data1.cab OK
    testing: L2_C3_Installer\data1.hdr OK
    testing: L2_C3_Installer\data2.cab Error: invalid compressed data to inflate
    At least one error was detected in C:\Documents and Settings\Stroke\My Documents\L2_C3_Installer.zip.
  2. kickarse
    kickarse What's a Dremel?
    6 Oct 2004
    what are you trying to extract?
  3. orb
    orb satisfying.
    23 Dec 2003
  4. Froggy
    Froggy What's a Dremel?
    10 Jun 2003
    sounds like your hard drive has bad sectors. Run scandisk. or go to start -> run -> cmd
    type chkdsk /f
  5. orb
    orb satisfying.
    23 Dec 2003
    0 KB in bad sectors
  6. Cheap Mod Wannabe
    Cheap Mod Wannabe What's a Dremel?
    7 Feb 2005
    Just reinstall WINRAR or WINZIP whichever you're using. This kind of problem used to happen often for me.
  7. orb
    orb satisfying.
    23 Dec 2003
    i'll try that now. thanks
  8. orb
    orb satisfying.
    23 Dec 2003
    Just re-installed winrar and tried extracting the file again, still says its corrupt.
  9. Froggy
    10 Jun 2003
  10. orb
    orb satisfying.
    23 Dec 2003
    Okay, i'll test that now
  11. Colonel Sanders
    Colonel Sanders Minimodder
    25 Jun 2002
    What broswer are you using? I suppose you have tried downloading the file again? I think you should try to get the file from another source too. Might even help to try 7-Zip.
    L J
  12. orb
    orb satisfying.
    23 Dec 2003
    i Just donwloaded that mem test program, do i burn it to CD or is there a way to run it from my hard drive?
  13. orb
    orb satisfying.
    23 Dec 2003
    I used FlashFXP
  14. orb
    orb satisfying.
    23 Dec 2003
    Ok, i ran the tester foraround 3h45m.
    Heres the things i have on my camera
    Code:
    Errors | ECC Errs
    2197     8
    If you need anymore info i got a picture of my screen from my camera, i hope i can get this fixed :wallbash:
  15. Froggy
    10 Jun 2003
    If you have even 1 error, thats bad. You have so many errors that i can easly determine that your have defective ram. If you have more than 1 stick, pull out all but 1 and test them 1 at a time till you figure out wich one is bad.
  16. orb
    orb satisfying.
    23 Dec 2003
    Yeah, i decided to try that, i found the defective one and im now im having fun creating havoc with a angle grinder..
    Although i still cant unrar this installer so im re-downloading it again now. Hopefully this will fix, thanks for the helps guys :D
  17. Firehed
    15 Feb 2004
    Well the source file could be corrupt as well... ie, something on the server's hard drive.
  18. orb
    orb satisfying.
    23 Dec 2003
    Maybe, but it is a offical website, so im pretty sure they'd have it fixed up pretty quick tho right?
