Allow or Cancel pop ups
Discussion in 'Tech Support' started by Ren, 14 Nov 2008.
  1. Ren
    Ren What's a Dremel?
    7 Nov 2008
    Hi everyone,
    on Vista when i run any setup or when i launch my lineage game for example, there is always little window pop's up askig to allow program or cancel the process.
    Is there any way to get rid of this messages forever?
    Because it is getting anoying now when i run some apps a lot of times and this keeps popping up.
    Hope you understand what i am talking about :D
    Thank you.
  2. Andersen
    Andersen Brain for hire
    25 Nov 2002
    Vista?
    That setting would be somewhere under Users in control panel. You'll want to disable UAC. Can't remember exactly where because I got rid of that OS ages ago.
  3. Ren
    7 Nov 2008
    Thanks. Found it.
    Now i got so less troubles :p Thank youu
  4. SpaceBaby
    SpaceBaby AKA: Stophon
    1 Aug 2008
    this is something i am having trouble with, how do i remove it
  5. Golygus
    Golygus Minimodder
    9 Oct 2003
    Control Panal
    Classic View (bit easier to get to the option you want)
    User accounts
    "Turn User Account Control on or off"
    I Advise you don't turn it off. It is there to protect your system after all. However, each to their own.
  6. Malketh
    Malketh What's a Dremel?
    22 Jan 2008
    Or you could install Norton's UAC Tool and tell it to always allow that program to run when the new dialog pops up.
  7. p2eky
    p2eky What's a Dremel?
    17 Nov 2008
    From Start Menu | Run type msconfig and disable UAC in there (choose far right tab and near the bottom).
  8. ozstrike
    ozstrike yip yip yip yip
    19 Sep 2004
    Check that these programs don't have any updated versions. Games shouldn't need to run with admin rights.
    Disabling UAC isn't a great idea though.
