Hey guys My pc keeps bluescreening, at first i thought it was the overclock, so i reset to default, still having problems. The error message is usually different aswel, but i can't seem to find how to upload the minidump files here, and i have no idea what they mean Can anyone help?
Right down the error code(s)- I used to get 0x0000008e alot, turned out to be some funky usb mouse driver issue ( would update to one of two drivers each time I ran the update, only one driver actually worked properly ). Any new hardware installed lately?
How maxed out was your overclock? Was it the highest stable you could get, or did you crank it back a bit to save pushing the hardware to the max? If I had a pound for every dead PC I've heard of owned by those that overclock to the max.... I'm not saying you've got dead hardware because of your overclock, but it's a possibility. It's also a possible that you've just got a borked windows install and sorting that out may fix it. I'd recomend grabbing a linux live CD and see if you can boot into that. If not then you've likely got hardware issues, so you'll need to start working out what it is... may be just the PSU, but it could also be the MB or CPU or...
Hi, i ran the memory test than can be accessed by pressing f8 at startup, it said problems were dectected, but didn't show me the results on next boot, i think because it failed to boot or something, so does this look like it definatly points to ram? i tried to upload a pic but for some reason its failing to upload atm
