Hardware Alpenföhn Atlas Review
Discussion in 'Article Discussion' started by Combatus, 12 Nov 2015.
  1. Combatus
    16 Feb 2009
  2. SuperHans123
    SuperHans123 Multimodder
    27 Dec 2013
    Giant Air Coolers...relics.
  3. Splooshiba
    Splooshiba Minimodder
    20 Jan 2012
    Nice review. Is there a typo on the test setup page?
    "Intel Core i7-4690K overclocked to 4.4GHz (44 x 100MHz) using a vcore of 1.25V"
    i5-4690K or i7-4790K?
  4. Vault-Tec
    30 Aug 2015
    I looked at it and initially thought that. Then I read the first page of the review and realised it uses 92mm fans.
  5. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    I'm not sure about the gap with the middle fan - it's obviously not going to be drawing much fresh air in through the gap, so I don't know why it's there. Surely it means one set of fins will be getting warm air blown through them (assuming it's blowing air onto the fins, then the order is outside fan->fins->centre fan->fins. If the outside fan is sucking, then the order is reversed, but the point stands), so that one set of fins will be less effective than the other?
  6. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
    Good spot, it's the i5!
  7. Dogbert666
    17 Jan 2010
    It can be either order as the second fan can be installed on both outer sides. I suspect Alpenfohn would argue that the upwards angling of the fins helps to direct their airflow in different directions. You're right though. Unavoidably one stack will be warmer than the other.
  8. Splooshiba
    20 Jan 2012
  9. Xir
    Xir Modder
    26 Apr 2006
    Humming waterpumps... noisy. :D
    Pricewise this one compares to the Macho Rev.B, which beats it hands on and should be a lot quieter.
    The Macho 90 is closer performancewise, but a lot cheaper.
Tags: Add Tags
