Alpha PAL8094 Suck or blow!!
Discussion in 'Hardware' started by couzo, 24 Jun 2002.
  1. couzo
    couzo What's a Dremel?
    26 Apr 2002
    I have a new XP2100+ and a Alpha PAL8094 and the fan is sucking at the moment and it's temp is 40 would turning the fan round and have it blow bring down the temps?
  2. jamiesurfs
    jamiesurfs Boom Boom, Cha Cha Cha!
    21 Oct 2001
    Best thing to do is just to try it m8! You can always change it back again. Mine is sucking as it happens and theoretically this should be optimal with efficient case airflow. Besides, the manual thingy tells you to put the fan on so it sucks, but try them both all the same!;)
  3. ViperZ
    ViperZ What's a Dremel?
    9 Mar 2002
    Alpha recommend that you suck the air away form the heatsink rather than blow through. However the optimal may depend on your case and equipments flow charateristics.
    I say run the test like Jamie stated :)
    Here is a link to Alpha that shows they indicate the HSF in Expulsion (sucking) has a better thermo coeffecient that blowing. 28C/W vs 32/CW.
  4. Lazy
    Lazy Meow?
    13 Nov 2001
    put it on suck then duct it on to a rear extract fan. :)
  5. ViperZ
    9 Mar 2002
    Exactly Lazy, I'm working on a air box for that now. If that fails I will duct it straight out the side of the window.
  6. Lazy
    Lazy Meow?
    13 Nov 2001
    i've got enough ducting to duct it outside :)
  7. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    stay with sucking...i tried out both, and unless you have a blowhole right above it(which you can turn around aswell) it will give u a 2-3deg improovement to blowing...:eyebrow:
  8. Lazy
    Lazy Meow?
    13 Nov 2001
    ahhhh doesn't that just blow? :D (yet another comedy pun)
