Thinking of buying a "Alphacool Cool Answer 120" for my system with a athlon xp cpu, the problem is that I dont have any holes around my socket. But on this pic the clamp looks like the clamp on the cooler I've got atm.. Anyone know if it works? Edit: Clamp.. hehe
By the looks of that, its a clamp, and it hangs off the ZIF socket thing. You don't need holes if i'm right
HI I have an AMD clamp like this, which isnt compatible with the new skt 754 and 939, therefore i think it it designed for skt A. Yatesy
