Hardware Alphacool working on cheaper graphics card waterblocks
Discussion in 'Article Discussion' started by Combatus, 16 May 2013.
  1. Combatus
    16 Feb 2009
  2. Tynecider
    Tynecider Since ZX81
    23 Jun 2009
    I would have thought £50 would be cheap no?
  3. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    This sort of manufacturing is probably a little more relevant for those not investing in £850 graphics cards and a watercooling setup...
    Still, it looks nice at least, and if it performs as mentioned then it's a strong contender. Thing is though, you're simply not saving very much. The blocks that retail for ~£40 more, like the EK XXL and Koolance NXTTN, generally include the backplate in their package, so really you should knock ~£25 off their prices. The next most expensive blocks are all nickel plated, unlike this block. So when comparing like with like, you're only saving £5/10 as mentioned in the article.
    Now if we start talking £50 for future, lower end cards then it's more meaningful.
  4. Big Elf
    23 Apr 2009
    It's an interesting concept and the test results seem pretty good but the price is way too high. They need to work on the aesthetics as well, this one is fugly.
  5. bodkin
    bodkin Overheating
    8 Apr 2009
    Steel and copper? Does that not lead to galvanic corrosion?
  6. The_Crapman
    5 Dec 2011
    I too am disappointed in the price and aesthetics. IMO the current crop of alphacool block are the best looking on the market, and considering they can be had for £76, this seems like a paltry saving at massive detriment to the looks.
    steel is a much more stable alloy, unlike copper, nikel and aluminium which are all elemental metals and therefore prone to enjoying the odd chemical reaction.
  7. riekmaharg2
    riekmaharg2 has completed the PowerCore scratch build
    22 Feb 2009
    Not with stainless steel I don't think.
  8. blackerthanblack
    blackerthanblack Minimodder
    17 Sep 2004
    An interesting design, but I think a stage further would be better with modular or adjustable inserts into the housing to suit varying cards - it would push the price up but as others have said, it's not that cheap anyway.
  9. Tangster
    23 May 2009
    The title really ought to say "cheaper Titan blocks". I was getting hopeful about alphacool's future blocks costing less than current ones, not that the Titan block is cheaper. Hopefully the tech will trickle down into the GTX760(or equivalent)blocks for next generation.
  10. phuzz
    phuzz This is a title
    28 May 2004
    Every time I think about watercooling my graphics card, I look at the prices for blocks and think "for that much I might as well wait a bit and upgrade my graphics card first". So I do upgrade, then I look at the price of blocks and think "for that much..."
  11. The_Crapman
    5 Dec 2011
    Strap an aio cooler on it. Rad, block and pump for 50quid. Bargain!
  12. Joey Propane
    Joey Propane What's a Dremel?
    26 Feb 2011
    "budget" and "Titan" don't really fit too well together in my opinion...
Tags: Add Tags
