Cooling alternative cooling methods...
Discussion in 'Hardware' started by scoob8000, 30 Apr 2002.
  1. scoob8000
    scoob8000 Wheres my plasma cutter?
    17 Feb 2002
    I was thinkin about water cooling the otherday, now ive never setup a watercooled rig, or even if this idea has come up before, but what if...
    I took say a aluminum resivoir with pump, and mounted a peltier or two to the outside of it to
    cool the liquid, would this work sufficiently enough to do away with the radiator?
    -scoob8000
  2. stewe151
    stewe151 Stress Personified
    9 Mar 2002
    wouldn't you stilll have to cool the Peltier?
  3. Lord_Vheox
    Lord_Vheox What's a Dremel?
    6 Feb 2002
    peltiers do need to be cooled themselves...
  4. Haddy
    Haddy World Domination
    22 Jan 2002
    its called a waterchiller and no it doesnt work very well and yes u still must cool the peltiers
  5. socketman
    socketman What's a Dremel?
    9 Apr 2002
    It has been tried. Its not nearly as efficient as you might think.
    Go the www.hardforums.com and go to their cooling section. Have a look around and you'll see about 5+ threads dedicated to the idea of water chilling.
    A way more efficient means to cool your water before it enters the CPU block is counter-current water jackets. Do a google search for counter-current anything... and you will get the idea.
    If your sharp enough you may come up a way to effectively water-chill. But so far noone has had much luck (even when routing the water through their home freezer).
  6. scoob8000
    17 Feb 2002
    i know pelts need to be cooled, but thats the easy part.. scratch that idea then..
    another one.. im sure this would work.. anyway, on my 72' project car I have a cool can.. what is a cool can you ask?
    simply you fill it with ice and run your fuel through the line and recirculate it for awhile before the race, its effictive to cool a tank of gas on a 80degree day to the point there is condensation on the fuel lines.. if its that effictive, what if we pumped water/coolant through it.. (on a hot day the ice lasts for about 4 or 5 hours)
    any takers?
  7. stewe151
    9 Mar 2002
    if you want to do extreme cooling, get an air conditioner and instead of running the cooled liquid to the fan for the house, run it to your CPU. it'll work good:D in theory you could do the same with one of those window ac. i would try it myself but i have no money:sigh: if someone wants to fund this project, i will do it:D
  8. Haddy
    22 Jan 2002
    lol ac running all day....i dunno whatthe electricity cost is over there but that would cost a fortune here in the states.....if u want extreme cooling tear out an old frig and use the cooling unit on that....just like a vapor chill......
  9. stewe151
    9 Mar 2002
    Hmm... i didnt think about that. ok, whoever is going to fund this for me also needs to get me some solar panels to power it:idea:
  10. scoob8000
    17 Feb 2002
    I guess i'll stick with my alpha 8045, its nice and cool all day.. 37c/98f full load oc from 1.33 to 1.5something.. :) then again, its always cold downstairs here, around 65f almost yearround.. dont know how, but its perfect for the pc's.. guess i'll test the temps in a warmer environment at the next lan im going to in june..
    -scoob8000
  11. *mat-ster*
    *mat-ster* What's a Dremel?
    10 Mar 2002
  12. eyescum
    eyescum What's a Dremel?
    15 Apr 2002
  13. mr. phantastik
    mr. phantastik What's a Dremel?
    7 Apr 2002
    The fridge idea is excellent, but the one thing you have to be careful of is handling the refridgerant. I know the States has laws about letting it into the atmosphere, etc. Its also incredibly dangerous to get it on your skin. We had a frdige guy come to the house once, and he had frozen his whole hand once in an accident. No feeling left, as he killed all the nerves off.
    With that said, its still the most effective way of chilling water. Its just a bitch trying to find a scrap bar fridge here in Canada.
