Graphics Alternative for Asus Smart Doctor
Discussion in 'Hardware' started by Buzku, 6 Jun 2005.
  1. Buzku
    Buzku What's a Dremel?
    7 May 2004
    Asus has Smart Doctor-program for adjusting graphic cards fan speed. The problem is that it works only w/ forcewares that are modified by Asus and those drivers crashes my games. Smart Doctor also likes to switch the silent mode for manual randomly. That pisses me off. So is there alternative solution for adjusting the fan? I would not like to break my warranty by installing Zalmans silent solution.
  2. Tim S
    Tim S OG
    8 Nov 2001
  3. Buzku
    7 May 2004
    I can't find any option for fan controlling in Expertool.
  4. DigitalX
    DigitalX What's a Dremel?
    26 May 2004
  5. Tim S
    Tim S OG
    8 Nov 2001
    I'm sure many people have used Expertool for controlling the noisy 6600 GT fans in the past. :confused:
  6. Hwulex
    Hwulex What's a Dremel?
    1 Feb 2002
    I do :thumb:
    I just installed it, ran it, and ssshhhhh; fan much quieter. :D
  7. Buzku
    7 May 2004
    Where is the option for fan slowing?
    EDIT: One of the buttons in Extool is grey, unclickable so I'll try coolbits.
    EDIT2: Installed coolbits 2, There seems to be no option for fan controlling in forceware :sigh:
  8. Hwulex
    1 Feb 2002
    Probably means it's not enabled on the card. Read about it in another thread in this forum. Think you'll have to update your graphics BIOS to enable temp sensoring and thus fan speed altering. :)
  9. Buzku
    7 May 2004
    Temp sensoring is enabled (Everest, for example, can show the temps) and fan controlling should be enabled if SmartDoc can do it?
  10. webbyman
    webbyman Hax.
    7 Oct 2004
    including me ;)
    you can find it in the performace settings theres a button with 'fan speed control' or something then a box pop's up :D
    nice and quiet ;)
  11. DigitalX
    26 May 2004
    Why cannot Asus make an separate program that controls the fan"s"..like small conf file where you just but, for example 50% save and execute the program and thats it. Why are they doing it the hard way?
  12. Buzku
    7 May 2004
    I can't understand why Expertool-thingie works with you but not with me. The lowest button is just gray.
