I'm doing a project (it's in the project logs under the name Delta) and I want to use Bulgin Illuminated switches, but 1 of them costs between $24 and $32 Cad, depending on the store and color. I'd like to keep a unified look to the front panel, so buying two is only an option if I can find a supplier that has their non illuminated switches in the same size. (21mm-22mm) Can someone: A- Point me to a Canadian or American store that carries the switches for about $15 - $20 Cad. B- Show me a Canadian /American store that carries the non illuminated switches. C- Give me an alternative momentary switch. Linky There are pics of what I want it to look like in the end in there if you are interested.
Definately not the same quality, but if you want it to look like one: http://forums.bit-tech.net/showthread.php?t=32590
I use these sometimes. Not as expensive, non-illiminated, but only 12 bucks... http://www.jameco.com/cgi-bin/ncomm...1&prrfnbr=5398&cgrfnbr=718&ctgys=503;523;718;
Are those domed or "low" switches? Code: By "low" I mean the switch face is flat, like this: /| | | | | \| Domed are more like this: /| / | ( | \ | \|
Read the data sheets for the switches.. Go to the Bulgin Website and find the vandal resist switch that you're thinking about buying. The link that Dad posted also has a data sheet available to look at. and yes... the low should be pretty much flat and the domed are domed...
I meant the ones Dad linked to, from Jameco. They look both domed and flat. I just looked at the tech doc and the cataloge page carefully, and they are the domed variety. But I may get them for another case that I have not finished. (It'll be posted in modding when done)
