Cooling Alternatives to Sythe GT's?
Discussion in 'Hardware' started by Tangster, 14 Jan 2012.
  1. Tangster
    23 May 2009
    In 120mm blue, black or white? Quite simply, the GT whine is a worry, since I'd probably take me about 3 minutes before I removed them out of sheer annoyance.
    The Phobya Nano 2G was my first choice, but it's red. :sigh:
    Help me out guys(and gals).
    EDIT: for a radiator, for reference, I have bunch of Yate Loon D12SL-12's laying around and a couple of Gelid Silent 12's.
  2. flame696
    flame696 Terminating People Since 1980....
    15 May 2009
    what do you need it for? HSF? Rad? case?
  3. Tangster
    23 May 2009
    Edited first post, it's for a radiator.
  4. flame696
    15 May 2009
    its hard to beat the GTs for rads. im not sure someone like bloody_pete or lennyRhys as they are up to date with fans for rads
  5. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    The old sycthe 1450 are what you need! Becoming rare though im afraid as thr newer models really do have a whine to them.
    I have installed them on a few occasions hoping that the next batch would be better, but have always ended up taking them out because I cant put up with the whine.
  6. dead beat
    dead beat Rippin six 4 life
    15 Feb 2009
    Aerocool Sharks are great for radiators. You can get them in a variety of colours too.
  7. Big Elf
    23 Apr 2009
    The new Swiftech Helix fans due out later this month look promising.
    I'm currently using Noiseblocker PL2s. They're a bit louder than the GT1450's but have a smoother sound. They're a bit pricey though.
  8. Tangster
    23 May 2009
    Opinions on the AC F12's? another potential option seem to be Scythe K-Flex's
    If those Swiftech helix's are any good I'll probably swap out in a few months.
  9. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
    I shall let you in on a little secret http://www.aquatuning.co.uk/product...le-Typhoon-Fan-1450-rpm---120x120x25mm--.html
  10. Mac_Trekkie
    Mac_Trekkie Source Engine's #1 fan!
    10 Sep 2011
    Is the rad on exhaust or intake? If it's intake you might want to go with Silverstone Air Penetrators.
  11. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Air pens aren't that good for rads, as they have fairly low pressure...
  12. Mac_Trekkie
    10 Sep 2011
    I should know that but I didn't, why didn't I? :wallbash:
  13. bdigital
    10 Aug 2010
  14. thetrashcanman
    18 Nov 2010
    Ah I suspect they probably are, my bad, shows you what happens after you get in from a 12hr shift at work D:
  15. bdigital
    10 Aug 2010
    Heh no worries bud - still decent fans, and certainly not as bad as the 1850s. But theres a particular batch of 1450s that are (in my opinion) the sweet spot between performance and noise.
    Sorry for thread derail!
  16. dead beat
    15 Feb 2009
    Are the 1850's loud even at lower rpm's, when used in conjunction with a fan controller?
  17. flame696
    15 May 2009
    no ive got my case on top of my table right next to my ear and the loudest thing i can hear is my F1's and i have 4 of them on my H100
  18. Seb.F
    Seb.F Minimodder
    17 Nov 2011
    bequiet Shadow Wings!
  19. LennyRhys
    LennyRhys Oink!
    16 May 2011
    flame696 is right - nothing will come close to the noise/CFM performance of a Gentle Typhoon for high-impedance use (radiator). The design of the impeller is just incredibly efficient for pressing air through the small interstices of heatsinks/rads and the funky bite marks on each blade help the acoustic performance.
    Scythe S-Flex SFF21F (1600rpm) are the next best thing but they are very expensive and you may find that you want to undervolt them or put them on a controller.
    What's your budget?
  20. flame696
    15 May 2009
    OMG someone sig this it's incredible Lenny thinks I'm right :D
    LennyRhys likes this.
