Modding aluminium drives...
Discussion in 'Modding' started by riyaz3000, 14 Mar 2002.
  1. riyaz3000
    riyaz3000 What's a Dremel?
    10 Mar 2002
    i'm on my second case and decided to go for a Lian Li but i dont wanna just stick on a bay cover and call that stealthed..
    does anyone know anything about electroplating?
    has anyone tried electroplating the bezel of a CD writer or DVD rom?
    will i be the first?.....
    woah...
  2. nsain
    nsain What's a Dremel?
    22 Jan 2002
    what is electroplating? sounds fun!!!
  3. Alaric
    Alaric code assassin
    3 Nov 2001
    lian li are gonna (or have) released some premade cd bezels ... u may wanna look into that too
  4. LaPPe
    LaPPe What's a Dremel?
    3 Nov 2001
    Nope, you wont be the first.
    I do not know of a UK store, but this Danish store has floppy as well as cd-rom bezels made for lian-li cases.
    Btw the site is in Danish only.
  5. enfer_know
    enfer_know What's a Dremel?
    4 Mar 2002
    aluminum + dremel = fun + aluminum bezel.....or disaster
  6. Alaric
    3 Nov 2001
    LaPPe thats what i was talking about in my previous post :p
    its just occured to me (i'm being a bit slow todaay) but to electroplate something doesn't it have to be a conductor (ie metal :p)
    therefore it wouldn't be possible to do a plastic bezel ?
    unless there is another form of electroplating i am unaware of:confused:
  7. riyaz3000
    10 Mar 2002
    electoplating plastics has been done i think they wash the plastic part u want electroplated with a conductive fluid..
    i cant buy pre-manufactured bezels for mine as they are a wierd shape...
    thing is i need advice becos once i do the drives... i want to do my optical cordless trackball and keyboard... i want EVERYTHING to match!!! everything HAS to be BLUE or SILVER... or it aint goin in... :D
  8. UnLoadeD
    UnLoadeD What's a Dremel?
    2 Jan 2002
    Check out this thread, might give you some ideas:
    http://forums.bit-tech.net/showthread.php?s=&threadid=5684
    I'm 99% sure you wont be able to plate your bezels and even if you did, they wouldnt match brushed aluminum. If you just want chomed look, there is something called silver leaf, and there is something similar that macroman used for the floppy door on macro case, check that article.
  9. Jordanis3r
    Jordanis3r Jigsaw Master
    8 Jan 2002
    hehe i was the first to do slot dvd plates---sold a few too---did this last summer and have done about 20 or so since then----
  10. riyaz3000
    10 Mar 2002
    do you reckon carbon fibre and aluminium go together?
    i was thinking of making a bezel using a blank bezel but facing the CD/DVD drawer with mock carbon fibre... it will match the top of the front panel.. (i have Lian Li usb60v2)
  11. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Electroless Nickel process (Google is your friend) coats most plastics very well, but is expensive.
  12. riyaz3000
    10 Mar 2002
    Look!!! it looks silly without matching drives.....
    :D
  13. riyaz3000
    10 Mar 2002
    FOUND IT!!!!
    here is the site to order a kit to elctroless nickel plate...:p
    gonna cost over 50 quid... well worth it though cos u can reuse it to do other bits and bobs... and its tough...
    since we share info i guess i should tell u wher i found it....
    electroless nicket plating kit
  14. riyaz3000
    10 Mar 2002
    PS: thank you cpemma
