Networks am I being thick?
Discussion in 'Hardware' started by gracie, 29 Oct 2006.
  1. gracie
    gracie What's a Dremel?
    29 Oct 2006
    Hello folks :)
    Some friends have a BT Voyager wireless Modem/Router. We set them up some years back and it has been fine. They have three computers connected - two Xpsp2 and one Windows 98.
    Recently they decided to go for 'Talk-Talk as their new ISP because Talk-Talk are offering free broadband, but they decided they wanted to do it through the Voyager rather than pay for Talk-Talk's Livebox.
    They contacted BT to tell them they were planning to change ISP's in a few weeks, but BT cut them off immediately, so they have had no internet contact for three weeks.
    Recently the Talk-Talk CD arrived ( though there is some issue about BT not releasing the MAC ( or something)), and they tried to go through the cd procedure to connect. They get to a place where they are told that they will need to reconfigure the Voyager's details and put in the Talk-Talk details instead, but they don't know how to do this, so they call me.
    I get there, thinking all I have to do is find out the IP for the Voyager, from one of the property sheets or IPConfig /all and the problem would be solved - but I couldn't get it from anywhere.
    IPConfig /all just brought up a block of ascii characters - nothing in plain language that I could use, so something is wrong there, the support tab in network connections gave me the IP for the computer, but just a blank space for where it would have the gateway address, and nothing I tried yielded any results. I took it all off and then put the Voyager CD back in to reinstall, but it seemed to think all was fine and just got to Finish without entering any configuration menus, and if I tried to connect via new connection in Windows, it would tell me the wireless device was disconnected.
    I am confused. I tried putting in 192.168.1.1 in the browser, but that didn't work either ( the computer address started with 162 I think), so I had to come away leaving a very disappointed young lad, who was sure I would do the biz for them as I have always been successful before in sorting out his computer problems.
    Is there anything else I can do to help them? There must be a way I can access the Voyager - it doesn't have to be on the web to give me its own IP. Otherwise they will have to buy the Livebox from Talk-Talk, which will be several more weeks delay I understand. I feel I have let them down :miffed:
  2. DougEdey
    5 Jul 2005
    Get the IP address of one machine on the network (Network icon or control panel) and replace the last digit with a 1 or a 2 in your browse.
    192.x.x.1 or 10.x.x.2 are the standard ones.
    If the MAC code hasn't been released then there may be a problem with Talk-Talk not connecting you.
  3. gracie
    29 Oct 2006
    thank you Doug. :)
  4. Draxin
    Draxin Seeker of Photons
    29 Nov 2001
    did you get it sorted out?
    because sometimes the modem will have a sticker on the bottom with the ip or address you need to use to get to the setup page
