Am I flogging a dead horse here..
Discussion in 'Hardware' started by Shadow_101, 11 Apr 2008.
  1. Shadow_101
    Shadow_101 Mudkips.
    12 Feb 2004
    Basically been upgrading bits and pieces of my system since I’ve had it, but I went to try a "demo" copy of Assassins creed, checked my specs and found I couldn’t even play it on min. :(
    450 Tagan
    S939 4200+
    ASUS A8N SLI Deluxe
    XFX 6600GT
    2 x 512 Coirsair XMS Pro (with stupid lights :))
    2 x 512 Coirsair Value RAM
    500 Seagate SATA2
    200 Seagate SATA
    160 WD My Book
    My question is really is it worth getting something like the 8800GT/S or is my system really too limited by its other spec?
  2. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    I've been running a fairly similar spec swap your chip for an 4600x2 and your gfx for an old 8800gts and your there. I can run crysis on mostly high about 30fps with little lag. I'm pretty sure it's cpu limited but for £150 it'll keep you going for another year or so then when you do have to upgrade the base system you've got a half decent graphics card.
  3. PHPASP
    PHPASP I LIKE TO CODE IT CODE IT I LIKE TO
    16 Mar 2008
    For £150 you could get a cheap c2d and motherboard, sell on the bits you have and upgrade from there.
  4. steveo_mcg
    26 May 2005
    But you still running a 6600gt which tbh is the problem.
  5. The cheapskate
    The cheapskate One custom title before Matty
    27 Oct 2004
    new graphics card. you need one any way, so even if you do want to go core 2 duo later on you can just stick the new card in.
    jobs a goodun.
  6. Aterius Gmork
    Aterius Gmork smell the ashes
    25 Sep 2007
    You could try to get a cheap 8800GTS 320/640 mb of ebay, it will be much cheaper than a new card, and less bottlenecked by your system.
