Um, you're building a case from scratch using a dremel? That would take forever. Get some better tools and you'll have fewer problems. I recommend + Jigsaw + Table Saw + Power sander + Drillpress
Or just get another plain wired one and do a bit of modding But yea I have found that dremels(multi-tools) are a bit unreliable. Did you buy actual dremel branded ones ? Because I bought a crappy B&Q one which didn't fit togethor with the flexible arm and I used it without it justing with the fixed blade and it broke, so went straight back. Then I bought a Draper one and after a couple of hours use the first weekend, it broke so I sent it back and got a replacement and have used that for a few hours and it seems ok. I thinkt he actual dremel brand ones look quite reliable but they do cost alot
oh, and as said above, I think maybe you have a bit too much faith in the flexibility of the dremel. to make a case I am pretty sure you are going to want a jigsaw, anless its some kind of very unconventional case
Where you located? If your in the US go to Sears and get a craftsman branded rotary (its a rebadged dremel) This way you can bring it back to ANY sears ANY time for a replacement. Craftsman has a lifetime warranty no questions asked.
dont give up, and does a power sander have ne use, i found one in the ose (the only electic tool expt my 20doller drill that has weird hammer action if i choose lol, )
ok i sort of forgot that i had left this open i have'nt given up but i have gone and got myself a new jigsaw, hammer drill and finishing sander still have yet to get a new dremel but th GF insisted on going and buying an Icute case anyway so i have to wait until i get a new system which should be by friday any luck before i start modding another case but seeing as this one will be all mine any ideas on what i should do to it at presents either a full tower a base unit, a pentium tower that looks like a set of steps or another midi tower. (i have a lot of towers around my local boot fair tends to have some one selling them for a fiver so i buy them just to rip apart
