Modding Amazing water-cooled PC in a desk
Discussion in 'Article Discussion' started by Claave, 16 May 2011.
  1. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    I have a question: The distance between the HD's and the motherboard is over a meter. (i am guessing here ) Then routing the SATA cables through the table. The cables must be at least 120cm long. Isn't this bad for the data transport from HD to Mobo and back ?
  2. Necrow
    Necrow Minimodder
    24 Feb 2009
    I always thought the G69T projects were the ultimate, however this is now a serious contender for one of the greatest projects of all time.
    G69T has some difficult competition lol
  3. Zurechial
    Zurechial Elitist
    21 Mar 2007
    I'm with kaiser on this.
    Even the best, least-conductive coolants will absorb metallic particles from the block surfaces and radiators they come into contact with, making them conductive over time.
    You're probably okay if spilling non-conductive coolant by Feser and the likes on your gear straight out of the bottle or if you get a leak/burst within a few months of building the loop; but over time that coolant will become as dangerous to electronics as tap water.
  4. mattbailey
    mattbailey What's a Dremel?
    26 Dec 2009
    Just host the party then!
  5. l3p
    l3p www.^.nl
    1 Nov 2010
    Thanks for all the comments guys !!
    The cables are even 200cm. That was one of the things i thought it would give troubles.
    But after 4 months running with 100cm sata+100cm sata extension i still didn't have any problem at all.
    There is one thing that can give problems, that are all the 12V cables with extensions.
    The voltage wil lower cause of the lengths.
    Thats why im using a 700W and a 800W psu now, no problems at all :p
  6. feathers
    feathers Minimodder
    11 Apr 2009
    Agree. And since it is clear even by looking at the labels on feser one versus feser bi-distilled that the feser UV is 10 x more conductive then at least by choosing the least conductive you are protecting your hardware for longer. My Thermochill EC6 is more than 12 months old but still non-conducting (it leaked on to my upper 560Ti from cpu waterblock nozzle which had been improperly secured. The GPU was running happily even with a blob of sticky honey-like liquid that had dripped on to one of the power transistors.
  7. Farfalho
    Farfalho Minimodder
    27 Nov 2009
    Don't care about being polite... I just had an erection and jizz right afterwards!
  8. l3p
    l3p www.^.nl
    1 Nov 2010
    Take it easy, don't want it to get the name "Jizz D3sk" :p
  9. GravitySmacked
    GravitySmacked Mostly Harmless
    2 Mar 2009
  10. GravitySmacked
    2 Mar 2009
  11. kylew
    kylew What's a Dremel?
    28 Apr 2007
    Why are people calling scratch built things "mods"? :confused:
    He hasn't modified anything, he's scratch built it.
  12. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    So cool I don't even have words to descr.......
    :lol:
  13. Fizzban
    Fizzban Man of Many Typos
    10 Mar 2010
    Definitely one of the best builds I've ever seen. It's amazing!
  14. paulp
    paulp What's a Dremel?
    6 Apr 2011
    I like the idea, and it looks incredible, but I wonder how much it costs. I imagine that just the radiator could be installed in a much simpler desk and sold for much less. This to will come after the initial marketing phase
  15. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    Spoil sport.
    Is it not a computer case that's been 'modified into a desk?
  16. b3z
    b3z What's a Dremel?
    8 May 2011
    Wow that is absoutley amazing, must of taken you a long time
  17. kylew
    28 Apr 2007
    Not if it's been scratch built it's not!
  18. Waynio
    Waynio Relaxing
    20 Aug 2009
    I can't be a total knob so congrats for making the front page Pete :thumb:.
    I'm completely turned off from mod comps with internet votes now but I'm not turned off modding :D:thumb:.
  19. l3p
    l3p www.^.nl
    1 Nov 2010
    Thanks a lot Waynio ! :)
  20. cport
    cport What's a Dremel?
    22 May 2011
    Tron PC!
Tags: Add Tags
