Blogs AMD’s 3rd Gen Ryzen has sent shock waves through the motherboard market
Discussion in 'Article Discussion' started by bit-tech, 6 Jun 2019.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    As if we hadn't been gouged enough over the last couple of years :eyebrow:.
    Worrying, very worrying :sad:.
    Genius move IMHO.
  3. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    The Asus Crosshair VIII Impact is the most interesting for me also, if those tiny fans for the VRM heatsink behind the rear I/O only start spinning when needed then take my money now.
  4. Mr_Mistoffelees
    26 Aug 2014
    Having upgraded to Ryzen+ last year, by the time I do another big upgrade PCIe 4.0 will be old hat, especially as I am gaming less and less as time goes on.
  5. Anfield
    Anfield Multimodder
    15 Jan 2010
    EK, Bitspower and the likes will probably be having a field day saving us from the X570 fan plague.
  6. faugusztin
    11 Aug 2008
    Until you buy the NH-D15 SE-AM4 and find out you need the NM-i115x Mounting-Kit to get your AM4 cooler on your AM4 board :D .
  7. Broadwater06
    Broadwater06 Minimodder
    10 Apr 2016
    What happened to prioritising to conserving power, given that climate change a serious topic, churning out sucking ever more juice high-end boards seemed a bit thoughtless. I could be wrong though.
  8. MLyons
    MLyons 70% Dev, 30% Doge. DevDoge. Software Dev @ Corsair Lover of bit-tech Administrator Super Moderator Moderator
    3 Mar 2017
    Although every little helps I don't think the extra 5w from a chipset is going to be an issue. Overclocking will use more energy.
  9. Mr_Mistoffelees
    26 Aug 2014
    5 watts on one motherboard is indeed insignificant but, by the time there are millions of X570 boards in use, we are looking at many Megawatts each day.
  10. Anfield
    Anfield Multimodder
    15 Jan 2010
    The production and disposal of the excessive retail packaging will probably be worse for the planet.
  11. Wakka
    Wakka Yo, eat this, ya?
    23 Feb 2017
    Would have been interesting to have got some statistics together on this forum a few years ago of the Intel/AMD ratio, then compare them once Zen 2 is fully out and people have made their upgrades.
    Just looking at signatures, I wouldn't be surprised if it was already around the 50/50 mark.
  12. B1GBUD
    B1GBUD ¯\_(ツ)_/¯ Accidentally Funny
    29 May 2008
    A somewhat wider dataset, the Steam Harware survey might prove useful?
    https://store.steampowered.com/hwsurvey/processormfg/
  13. IamSoulRider
    IamSoulRider Minimodder
    24 Aug 2016
    The only problem with the Steam hardware survey, they seem very keen to regularly check my ancient (4760K) Intel system for the survey, but haven't once decided to check my newer AMD rig. Both run side by side. I am not sure the survey is an accurate reflection, but of course am limited to my single example.
  14. B1GBUD
    29 May 2008
    That's weird, do you use seperate Steam accounts on each machine or the same account?
  15. IamSoulRider
    24 Aug 2016
    I use both, I use my own on both, and when friends come over, they use their own accounts on the new machine.
Tags: Add Tags
