Amd 2000+XP & bus speed question
Discussion in 'Hardware' started by WireFrame, 19 Jan 2004.
  1. WireFrame
    WireFrame <b>PermaBanned</b>
    24 Feb 2003
    I'm getting a 2000+XP processor in about a week, and I am currently running pc2100 DDR RAM. Will I need faster RAM? I know the AMD runs a 266 bus.
    Any help will be appreciated....
  2. phaSe
    phaSe What's a Dremel?
    4 Jul 2002
    hi wireframe,
    a quick search on google shows that PC2100 is infact DDR 266 Mhz, so you will be fine :thumb:
    Although, depending on the RAM you may want to upgrade to something faster if you're planning on OCing much....
    RoB
  3. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    And dont plan on overclocking much, the XP2000 is a palamino which not overclock well at all, I know - I tried.
    But yeh it runs at 133(266) default the same as your RAM
  4. WireFrame
    24 Feb 2003
    w00t. Thanks guys. I tried googling, but clearly came up with the wrong answers.
    ATM I havent got anywhere near the kind of setup that would allow OCing. My airflow is practically non-existant, and TBH I havent OC'd anything for a good while now. I'm just happy to be moving away from my 800 Duron :D
  5. phaSe
    4 Jul 2002
    hehee have fun! :D :D
    RoB
  6. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    Yoda... the newer 2000's have come out in a t/bred flavour... they dont oc as well as the earlier 17/18's but a lot better than the old pallys...
  7. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    Forgot the newer ones were T-bred's, the XP2000 pally I had was lucky to gain an extra 100Mhz.
