News AMD announces Zen 2 CPUs, feat. 12-core Ryzen 9 3900X
Discussion in 'Article Discussion' started by bit-tech, 27 May 2019.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. The_Crapman
    The_Crapman Don't phone it's just for fun. Lover of bit-tech
    5 Dec 2011
  3. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    I'm not surprised, not thrilled, but gently impressed and excited.
  4. TechnoMod87
    TechnoMod87 What's a Dremel?
    13 Nov 2012
    need only benchmark...
  5. zimano
    zimano What's a Dremel?
    1 May 2014
    The_Crapman, How dare you post a picture of my Mrs on here!
    The_Crapman and Vault-Tec like this.
  6. Anfield
    Anfield Multimodder
    15 Jan 2010
    Given how the Asus mobo PR dude was squirming when 16 cores got mentioned... I reckon it can't be too long before AMD stops playing around and announces it.
  7. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    Well that didn't last long; PCIe 4.0 CPU lane support now confirmed to be exclusive to 5xx series chipsets, will not be enabled for any existing motherboards.
  8. MLyons
    MLyons 70% Dev, 30% Doge. DevDoge Lover of bit-tech Administrator Super Moderator Moderator
    3 Mar 2017
    Makes sense to be honest. Looks like it uses quite a bit more power chipset wise
  9. Wakka
    Wakka Yo, eat this, ya?
    23 Feb 2017
    Plus, how many years/generations of GPU until the extra bandwidth actually makes a difference? Are we even saturating PCI-E 3.0 X16 at 4K yet?
    Navi being "Gen. 4" is a bit like Nvidia with ray tracing - it's a USP to add some marketing flavour and techy buzzwords, but it isn't going to make a lot of difference to end users for a while yet...
  10. MLyons
    3 Mar 2017
    IIRC the PCIe is more for workstation and scientific type loads on GPUs and for storage more than gaming
  11. edzieba
    14 Jan 2009
    It's nothing to do with the chipset. Previously it was announced that direct-fromCPU lanes (not chipset PCIe lanes, those are stuck on 2.0 for all current Ryzen chipsets) would be able to run at PCIe 4.0 speeds with a 3000 series CPU. This has now been reversed, and only boards with X570 (and presumably future 5xx series chips) will support PCIe 4.0 direct from the CPU.
    Barely even saturating x8 with a pair of the toppest-of-the-top-end GPUs in SLI.
  12. Wakka
    23 Feb 2017
    Also, side note - If the $499 price of the 3900X translates as the usual £499, this could well be the first genuinely top-end CPU I buy since I spent £600 on a QX6850. Would I need that much extra over a 3600/3700? Nope. But it would be a machine built to last a minimum of 6-7 years.
  13. perplekks45
    9 May 2004
    This.
    My current CPU is a 3770K, before that I had one or two stop-gaps, before that I ran a C2D E6600 @ 50% overclock for years. I just want a CPU/mainboard/RAM combo that serves me well for 3+ years.
  14. sandys
    sandys Multimodder
    26 Mar 2006
    This is surely because data is also sent over sli/nvlink bridges right?
  15. Vault-Tec
    30 Aug 2015
    Depending on IPC and how it plays with 2666mhz DDR4 this could be the first CPU I bought in over 2yrs.
  16. adidan
    25 Mar 2009
    I just did a little wee.
  17. edzieba
    14 Jan 2009
    More that it required two GPUs to start saturating the bus with CPU/RAM-to-card traffic before x8 started to noticeably impact performance.
  18. Calle2003
    Calle2003 What's a Dremel?
    24 Sep 2009
    Why is AMD Ryzen 7 3700X TDP 65W and AMD Ryzen 5 3600X TDP 95W, typo?
  19. Calle2003
    24 Sep 2009
  20. perplekks45
    9 May 2004
    Probably higher all core turbo and/or longer sustain thereof.
Tags: Add Tags
