AMD Athlon 64 FX-57
Discussion in 'Article Discussion' started by The_Pope, 27 Jun 2005.
  1. The_Pope
    The_Pope Geoff Richards Super Moderator
    3 Jul 2003
    http://www.bit-tech.net/hardware/2005/06/27/amd_fx_57/1.html
  2. The_Pope
    3 Jul 2003
    Definitely one for those who *have* to have the best, at any cost. I have read about several clocking to 3.6Ghz with phase-change cooling...
  3. TMM
    TMM Modder
    12 Jan 2004
    FX-55 has done 4.0ghz @ Xtremesystems, so it'll be interesting to see what the nutters around the globe get up to with these FX-57s :)
    More details on the processors used? afaik theres a 2.6ghz 512kb cache 4000+ and a 2.4ghz 1MB cache 4000+
  4. Tim S
    Tim S OG
    8 Nov 2001
    the 4000+ was a 2400MHz Sledgehammer, as reviewed back at the fx55 launch.
  5. Firehed
    15 Feb 2004
    Sounds nice, but I think I'd rather go for an X2 setup. Especially as I multitask quite a bit, and the real-world gaming results are about the same across the line. A fun bench to throw in there would be xvid encoding while mp3 ripping (or something like that), just to see how the extra mhz compares to a second core in multitasking.
  6. Latvietis
    Latvietis New Member
    8 Jun 2005
    You also should have made a test where you overclock FX-55 to FX-57 speeds and then we would see how much we benefit from 90nm process.
  7. Lost.Soul
    Lost.Soul New Member
    26 Oct 2004
    The high resolution game benchies made me laugh... 0,1 fps gain compare to FX55... Its not as good as I expected :miffed:
  8. webbyman
    webbyman Hax.
    7 Oct 2004
    :hehe: looks pretty cr*p if you ask me :eek: :duh:
    didn't exactly clot well either :hehe:
    value for money... :rolleyes: :eyebrow: nope :eeek: :hehe:
    edit: me thinks it more to do with GPU limitations :)
  9. ou7blaze
    ou7blaze sensational.
    5 May 2003
    Sounds crappy... :sigh:
  10. The_Pope
    3 Jul 2003
    It's only "crappy" at high resolution gaming, when you are heavily GPU limited - I'm sure Tim will be benching 7800GTX SLI on it at some point to test that theory. The X2 is arguably a better buy in terms of future-proofing, but let's just see how pricing settles down after the initial demand is satisfied
  11. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    And while you're at it, why not check how high the FX-57 goes on aftermarket heatsinks like the Zalman 7700? ;)
  12. mclean007
    mclean007 Officious Bystander
    22 May 2003
    Yeah, or on a high performance WC rig, or phase change? You know you want to crank up that Prommie! :D
  13. Tim S
    Tim S OG
    8 Nov 2001
    the higher resolutions are there as they are more 'realistic' settings that you might use for real-world gaming... that is the theory behind including those results. surely you arent going to buy an X2 4800+ or FX57 and game at minimum detail. :)
    Re: coolers... I shall see what i can do.
  14. Have you/have you thought about comparing the fx4800 with the fx57 in some benchies? :rock:
  15. yodasarmpit
    yodasarmpit No longer the other Brett.
    27 May 2002
    Thats obviously down to reaching the graphics card limit, maybe with the new nvidia 7800 we would see a bigger increase.
  16. Tim S
    Tim S OG
    8 Nov 2001
    the x2 4800+ has beenincluded? :worried:
  17. Stephen Brooks
    Stephen Brooks New Member
    24 Apr 2005
    I'm amused by the way you don't include any Intel processors _at all_, presumably on the assumption that they'll all be crap.
  18. Tim S
    Tim S OG
    8 Nov 2001
    I've not had a working intel platform available to me for about 2 months now - it's frustrating. Hopefully that will change very soon when I have a look at some stuff that arrived the other day.
  19. Da Dego
    Da Dego Brett Thomas
    17 Aug 2004
    Ummm, I don't think I've ever seen a review that was that one-sided by any intent. I would figure biggles has a pretty good reason for that oversight.
  20. padrejones2001
    padrejones2001 Puppy Love
    17 Jun 2004
    Well, here's another review. The P4's aren't doing half bad these days, so I wouldn't go around parading that they're crap for losing by only a few frames a second.
Tags: Add Tags
