Hardware AMD ATI Radeon HD 4770 512MB
Discussion in 'Article Discussion' started by Tim S, 28 Apr 2009.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. p3n
    p3n What's a Dremel?
    31 Jan 2002
    Nice to see an improvement in power consumption, its depressing that the same silicon could be many factors more powerful if they stopped with the clock speed/shader juggling
  3. Spiny
    Spiny What's a Dremel?
    6 Sep 2006
    Nuts! Not long bought a gts250
  4. frontline
    frontline Punish Your Machine
    24 Jun 2007
    Nice review, will be interesting to see what happens to 4850 prices too.
  5. Tim S
    Tim S OG
    8 Nov 2001
    Interesting, the price on Ebuyer has already dropped from £83.05 to £79.99 :eeek:
  6. Turbotab
    Turbotab I don't touch type, I tard type
    4 Feb 2009
    Probably the reason for the temporarily dead link, great to see the same drivers used on each family of cards, the best graphics card reviews, now with a cherry on top!
  7. Gremlin
    Gremlin What's a Dremel?
    31 Aug 2008
    No overclocking? or is that saved for a separate article?
  8. azrael-
    azrael- I'm special...
    18 May 2008
    Does the HD4770 really come with this cooler? From what I've read and seen elsewhere the cooling solution is more like this.
  9. M4RTIN
    M4RTIN What's a Dremel?
    11 Sep 2006
    finally looks like my 8800gt has been well and truly bested at the low end, still it has lasted a long time. so are they killing the 4830 now since it has no point
  10. DaMightyMouse
    DaMightyMouse What's a Dremel?
    1 Aug 2008
    Great review :) BTW Cross fire review planed for 4770 ?
  11. eek
    eek CAMRA ***.
    23 Jan 2002
    Looks like a good card for the money!
    I understand why you tested it using an i7 940 @ rediculus clocks, but it really isn't very representitive of the sort of system people are likely to be wanting to use this on. Is there any chance of some benches on mid-range hardware?
  12. Tim S
    Tim S OG
    8 Nov 2001
    It was one thing we wanted to do, but ran out of time because we had to re-run our Far Cry 2 numbers a few times to be doubly sure that they were correct. There are a couple of retail cards in house already that'll be reviewed in traditional fashion and if there's time today, I'll pop down and see how well the reference card overclocks. I'll update in a blog post over the next day or so and add an addendum to the article. :)
  13. Guest-16
    Guest-16 Guest
    That's Sapphire's aftermarket solution
  14. mclean007
    mclean007 Officious Bystander
    22 May 2003
    Nice review - one correction
    640 is 20 per cent fewer than 800, not 25%.
  15. azrael-
    18 May 2008
    Apparently then it's also HIS', PowerColor's, MSI's and
    Gigabyte's "special" aftermarket cooler... :p
    Haven't bothered looking up more manufacturers.
  16. Tim S
    Tim S OG
    8 Nov 2001
    Thanks - fixed. /brainfart
  17. Guest-23315
    Guest-23315 Guest
    My £104 4850 at Christmas still seems a bargin :D
  18. Gremlin
    31 Aug 2008
    Totally understandable! I think we are all dying to see just how well 40nm can be pushed :D
  19. Guest-16
    Guest-16 Guest
    Muahahha someone got a cheap ODM deal :D
  20. Paradigm Shifter
    10 May 2006
    Very impressed with the performance for the price. Would have been interested in seeing how a 1GB card compared at the higher resolutions like 1920x1200, but I can go look at other reviews and piece it together myself. ;) (I only ask this because... well, Oblivion chews up a lot more than 512MB of graphics RAM when using some of the HQ texture mods. :D And yes, I still play Oblivion. The wealth of mods out there make it a whole new game.
    AMD/ATi have pulled some fantastic technical achievements with RV770.
    Maybe there will be a slightly underclocked single slot cooler model that doesn't require the 6-pin PCI-E for HTPCs? If it draws 80w max, that isn't much power draw to cut off...
Tags: Add Tags
