Hardware AMD ATI Radeon HD 4770 512MB
Discussion in 'Article Discussion' started by Tim S, 28 Apr 2009.
  1. azrael-
    azrael- I'm special...
    18 May 2008
    Either that, or there's a special "reviewer's edition". The reason I asked in the first place was because I read about it over at ExPreview.com.
    As of right now it seems impossible to get a HD4770 with the "reference" cooler. None of the manufacturers I've checked (and I checked a few more since last) have any HD4770 resembling the one tested at bit-tech and elsewhere. I'm not really liking this, to be honest...
  2. azrael-
    18 May 2008
    XBitLabs claim it doesn't get near 80W at any given time. Seems like ATi put the connector there just to be on the safe side.
  3. Paradigm Shifter
    10 May 2006
    Fair enough - but I bet the card complains if you don't give it the PCI-E power line. :(
    Seems like ATi want overclockers to be able to break 1GHz with this. :D
  4. Guest-16
    Guest-16 Guest
    Stop looking for a conspiracy :p
    ATI probably just relied on partners to send out their own cards and because competition is so tight quite a few seem to have got a good deal on this cooler.
    Just be concerned with "reference" clock speeds - if ATI ships out pre-oc cards then that's a no-no.
  5. Turbotab
    Turbotab I don't touch type, I tard type
    4 Feb 2009
    I'm already bored with 40nm cards, I want 32nm parts now! :p
  6. azrael-
    18 May 2008
    That's what they all say ...just before they come and get you! ;)
    To be honest, I'm quite a bit interested in the cooling and noise properties since I plan to pick up a HD 4770 for a friend's birthday. He has a HTPC, but would like a bit of graphics power for the odd game as well. :)
  7. storm_temple
    storm_temple What's a Dremel?
    19 Jan 2009
    Its a very good value card
    Anyone notice some missing power choke or vrms ( sry not im not electerate)
    going to be some ATI HD 4790!?
    i think i skip and w8 hoping a 4790 will come along
    Turbotab 11 minutes ago
    Estimated Die shrink -40nm - 32nm -16nm -8nm -4nm
    -2nm 1 gigazillion transistors on 100mm2 drawing 1watts @@ by 2090
  8. Veles
    Veles DUR HUR
    18 Nov 2005
    I think it might be time to change my 7800GTX 256Mb
  9. heir flick
    heir flick Minimodder
    2 Feb 2007
    for just over £160 for a pair it would be intresting to see some crossfire benches, it could be a serious bang for buck set up
  10. Shielder
    Shielder Live long & prosper!
    26 Jul 2007
    Okay, I've got an 8800GTS 512 (G92 core). How will this new card scale compared to my 8800? Am I correct in thinking that the 9800GT is basically the same as the 8800GTS?
    I'm also waiting for the Crossfire review. X38 mobo don't allow SLi :(
    Andy
  11. uncle_fungus
    uncle_fungus P/T Folding@home developer
    27 Mar 2009
    I know I mentioned this last time, but can you fix your graph generation scripts such that f@hmon -> FahMon please?
  12. Tim S
    Tim S OG
    8 Nov 2001
    Ah, cripes. I didn't realize it was in the graph as well :blush:
  13. uncle_fungus
    27 Mar 2009
  14. Goty
    Goty Minimodder
    13 Dec 2005
    I'm surprised that you only gave it a 7/10 on value, actually; I might have considered an 8/10 or a 9/10 if I was feeling particularly happy that day.
    The GTS 250 is expensive enough to really make a difference in my book, and speculating on price cuts that haven't even been rumored yet isn't very sensible. If you're going to take that route, why not just go ahead and give the 4890 the best value of all? Heck, they'll be down to £90 in a few years!
  15. Cupboard
    Cupboard I'm not a modder.
    30 Jan 2007
    I had my old 7950GT (accidentally) running without a PCI-E power connector for quite a long time and it behaved absolutely fine.
  16. Zurechial
    Zurechial Elitist
    21 Mar 2007
    It depends on the card - Some cards won't allow your system to get past POST without connecting PCI-E power.
    Some cards need it, period; some cards need it when under load and other cards use it as a precaution.
  17. Furymouse
    Furymouse Like connect 4 in dagger terms
    4 Feb 2004
    I see some crossfire with my 4850 in my near future :D
  18. Tim S
    Tim S OG
    8 Nov 2001
    We were going off the original price quoted to us, which was £87 inc. VAT from Overclockers UK - at that price, it's very close to the GTS 250. At £79.99, I think it's an 8 or 9/10 for value as you say... but we don't adjust our scores after publication time. (if we did it to reflect every price change, it'd be a whole lot of extra work - it's one rule for all)
    It shows how this part of the market is incredibly sensitive to price - it's a steal at £80.
    I heard some fairly solid rumours that Nvidia was going to cut the price from a good source on Monday. That's why I mentioned it.
  19. Sark.inc
    Sark.inc What's a Dremel?
    9 Dec 2007
    can i have a link to somewhere explaining the benefits of a seal choke?!?!
  20. Guest-16
    Guest-16 Guest
    Marginally better ESR (cant remember acronym) protection and far better environmental protection - it doesn't corrode, especially in high humidity or coastal areas.
Tags: Add Tags
