Hardware AMD ATI Radeon HD 5970 Review
Discussion in 'Article Discussion' started by Claave, 18 Nov 2009.
  1. en8800gt
    en8800gt What's a Dremel?
    18 Nov 2009
    what the review it is man?
    it was better take look to other site.techpowerup gave 9.5/10 and charts are diffrent .
  2. NuTech
    NuTech Minimodder
    18 Mar 2002
    Holy crap that's about £350. Doesn't that effectively make this card a bargain in the USA?
    If you fail to take value for money into account, then no doubt the overall score sky rockets. But any review that ignores value is worthless in my eyes. Medium range cards that offer fantastic performance for money will then receive average reviews, and only super performers getting a 9 or 10?
    Like everything else, computer hardware doesn't exist in a vacuum, scoring it as such is a waste of everybody's time.
  3. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    i'll take 2 :S
  4. Baz
    Baz I work for Corsair
    13 Jan 2005
    http://www.techpowerup.com/reviews/ASUS/EAH5970/6.html
    techpowerup tested the nvidia cards with 6 month old drivers ( 186.18) We tested the GTX 295 with brand new nvidia drivers (191.06) and ATi cards with 9.10 catalysts. Don't mistake lazy benchmarking for a better review.
  5. Meanmotion
    Meanmotion bleh Moderator
    16 Nov 2003
    Um, the card is 12.2 inches long. The PCB is 11.5inches.
  6. Deadpool46
    Deadpool46 What's a Dremel?
    28 Jul 2009
    Hey Guys,
    You mentioned the poor AMD drivers and I noticed you listed the Catalyst 9.10 as the ones used in the test, I've seen other sites use the ATI Catalyst 8.663.1 Beta 4.
    Assuming it's not a typo, could this be the reason why you're not seeing great numbers?
  7. -Acid-
    -Acid- What's a Dremel?
    10 Nov 2004
    Some of your test's show the rig you used to be sooo CPU limited it was scary
    Lets be honest here if your going out to spend £500 ish on a gpu are you really going to run it on a 3.2 i7 ?
    I dont think so
    Do the card some justice and run it on a 4ghz i7 and lets see how much horse power it really has
    I unterstand the time and effort that goes into making a review but if something is worth doing then its worth doing right !!!!
  8. Star*Dagger
    Star*Dagger What's a Dremel?
    30 Nov 2007
    Because BT is lost in space these days.
  9. Grimloon
    Grimloon What's a Dremel?
    4 Sep 2008
    I use 3 22" widescreens for a desktop resolution of 5,040 x 1,050. Fantastic when you can get it to work but at the moment it needs two video cards and software triple head which is finicky to say the least (as well as only DX9).
    I'd be interested to see what actually supports this as at the moment as well as what the performance is like as you're looking at around 30% more pixels than are used at 2,560 x 1,600.
  10. Er-El
    Er-El Minimodder
    31 May 2008
    Still touchy about the MW2 review then? :hehe:
  11. Yadda
    Yadda Minimodder
    25 Jul 2003
    It would be nice if there was some software to make use of the available power on a single screen, instead of plying us with money-sinks such as hugely expensive multiple monitor setups to make use of the performance available from the biggest & baddest hardware.
    Come-on software developers, design some sexy new eye candy to make use of this power - it feels like we're treading water a bit (unless you want a multiple monitor setup of course).
  12. Horizon
    Horizon Dremel Worthy
    30 May 2008
    I'm disappointed that it doesn't come with the same cooler as the engineering sample.
  13. Evildead666
    Evildead666 What's a Dremel?
    27 May 2004
    Memory amount for the CPU is impacted by a 32or 64bit OS.
    Graphics cards don't share the memory with the OS, so it could have 80Gb or memory, it would make no difference which OS was used...Its Graphics memory...
  14. Evildead666
    27 May 2004
    Nothing to do with 64bit OS or 32bit OS,
    It could run under Win98 if it wanted to and the drivers alloed it to.
  15. Turbotab
    Turbotab I don't touch type, I tard type
    4 Feb 2009
    VRAM is not used by the OS*, but it still needs to be addressable. The 32-bit memory limitation regards the address space, and thus the larger the amount of Vram on your GPU, the larger an address space it will need. So good luck with your 80 GB GPU on a 32-bit OS:hehe:
    *expect for features like Aero in W7 etc,
  16. Horizon
    30 May 2008
    beat me to it
  17. SNiiPE_DoGG
    SNiiPE_DoGG Engineering The Extreme
    14 Apr 2009
    not sure how you guys always manage to cripple the ati card your testing but honestly you have some serious issues with your test bench.
    for example: on DoW2 you guys got 77fps average on 2560x1600 4xaa - where as TPU got 129.9 FPS
    in crysis @ 1920x1200 4xaa you guys got 58fps average - TPU got 74.5 fps
  18. Action_Parsnip
    Action_Parsnip What's a Dremel?
    3 Apr 2009
    Thats a tad rich given how long you guys were on old drivers for. You were using cat 9.4 and Forceware whatever.whatever for a long long time. And you call techpowerp lazy! Geeeeeeeeeeeez
  19. Action_Parsnip
    3 Apr 2009
    Is that actually true?? then why does my 32bit xp 4gb ram and 4870 512mb setup gives windows as having 3.25gb ram??????
  20. Action_Parsnip
    3 Apr 2009
    Ah sorry Turbotab and horizon, didnt see your replies. Misinformation spreads like wild fire on the internet tubes....
Tags: Add Tags
