Case Mod - In Progress AMD Bulldozer 8-Core Tribute - FINISHED!
Discussion in 'Project Logs' started by TheGreatSatan, 25 Sep 2011.
  1. TheGreatSatan
    TheGreatSatan Dark Lord of BT!
    5 Aug 2005
    Sponsored by:
    I've been running this through my head since the begining of the year. I knew that AMD would soon be releasing an eight core CPU code-named: Bulldozer. I also knew that I had to do a tribute mod too.
    My very first sketches have always started with the Cooler Master HAF 912.
    Within a few minutes I quickly stripped the whole thing down
    My choice of paint just has to be John Deere Yellow
    And it goes on easy and looks incredible
    I always love to have strong contrasting colors within the case
    I also strive for color consistency with matching bay drive covers too
    Then I stack two Cooler Master 120mm fans for the intake
    I didn't recolor the black plastic because it was already perfect
    I'll be customizing the right panel next
    As usual, I painted the DVD drive too
    More to Come
  2. TheGreatSatan
    5 Aug 2005
    I cut the window out
    And slapped on a coat of paint
    Time to work on the right panel. I'm going to be adding a couple of intake fans. The first is a slim 120mm behind the processor
    I cut from the inside out as to not damage the paint if I lose control of the hole saw
    My fan of choice is usually made by Scythe
    Here it is mounted. Because I went with a larger 120mm fan, I'll need to put the panel on first then screw it in place. The size of the fan interferes with the panels' slide latch
    I'll dress up the outside soon enough
    But first I'll need to cut out a spot for a 92mm fan behind the hard drive cage. Unfortunately, I don't have a hole saw that size available just yet...
  3. Sheiken
    Sheiken Wat?
    9 Jan 2005
    I will be following this one for sure!
  4. Tangster
    23 May 2009
    Looks like a worthy use of a HAF case. You putting a Bulldozer system when it's out?
    Sheiken likes this.
  5. bulldogjeff
    2 Mar 2010
    Off to a good start, yellow and black is always a winning colour combo.
    I wouldn't hold your breath on Bulldozer, I've had my build ready since mid June waiting for it and there's still no signs of it. Bulldozers had more delays than the London underground.
    I love AMD stuff but if it doesn't arrive very soon my next project will be Intel based.
  6. TheGreatSatan
    5 Aug 2005
    AMD is sending me the 8 core processor and a video card
    OCZ is sending me the new 1TB Revo Hybrid PCIe 4x card
    Enermax is sending me an 80 plus Platinum PSU
    I'm working with Swiftech to get a water-cooling setup
  7. KidMod-Southpaw
    28 Sep 2010
    Nice one on the sponsorship products! And what a great colour combo, keeping an eye on this for sure.
  8. Cheapskate
    13 May 2007
    I know you. You will have the case done before any of the kit shows up.:lol:
    Will anything made by Tonka be sacrificed to create your new minion?
  9. TheGreatSatan
    5 Aug 2005
    You are right on the money! I ordered a Tonka front shovel!!
  10. TheGreatSatan
    5 Aug 2005
    I picked up this excavator ride on toy at K-Mart for $40
    Of which I removed the base with treads
    And it's a perfect fit!!:banana: I just have to touch up the paint.
    I used several rivets to attach the case to the treaded base
    But then I realized that I choked off the PSU's air intake
    So, I decided to drill out the holes in the plastic. I can't quite get the drill into all of the holes, but I'll have a really awesome power supply provided by Enermax that will have no trouble getting enough air
    Then I got this air vent at Lowes for $6
    It just needed to be cut to fit the right panel CPU intake and then a little paint to match
    sb1991 likes this.
  11. stonedsurd
    11 Mar 2009
    Excellent work so far. :thumb:
  12. Halchart
    Halchart What's a Dremel?
    26 Jul 2011
    Looking real awesome! I like the concept.
  13. dream1
    dream1 What's a Dremel?
    26 Feb 2011
    Looking good men :D:D:D
  14. KidMod-Southpaw
    28 Sep 2010
    I think the excavator needs to be resprayed with your yellow, other than that it looks wonderful!
  15. TheGreatSatan
    5 Aug 2005
    ^I will. I also have to make it look a little more realistic too
    I bought a new 92mm hole saw
    And then cut the second intake
    The hard drive intake is perfect, but the CPU wound up being a bit off
    I added the vent. I still need to bondo the edges and paint the hinges yellow
    I'll still have to paint the other grill yellow too
  16. KidMod-Southpaw
    28 Sep 2010
    Those grilles look really cool- nice work!
  17. TheGreatSatan
    5 Aug 2005
    I bought this bulldozer shovel off ebay. It came from a Tonka T-9.
    As you see it'll be a perfect fit
    First I trimmed off the excess.....
    .....to make it attach to the front bezel and not the side panel. That way it won't interfere with the sliding door
    I spent a while sanding off the 40 year old paint and rust
    Then gave it a nice smooth coat of new black paint
    Next I'll be cutting the panel striping
    And adding the number 8 to the left panel. What do you think it signifies?
  18. nlancaster
    nlancaster Minimodder
    21 Dec 2009
    brilliant
  19. TheGreatSatan
    5 Aug 2005
    Thank you. I finally have a day off today after 7 straight and plan to use it wisely.
    I added the number eight and some striping to the lefft side
    I got back to finishing the vents, but still need to fix the edges and stripe this side too
  20. TheGreatSatan
    5 Aug 2005
    I attached the shovel to the front bezel
    And that's on.
    Still more to do, for sure
