Case Mod - In Progress AMD Bulldozer 8-Core Tribute - FINISHED!
Discussion in 'Project Logs' started by TheGreatSatan, 25 Sep 2011.
  1. TheGreatSatan
    TheGreatSatan Dark Lord of BT!
    5 Aug 2005
    I have that same fear......
    I painted the seams and rivets to match the rest
    Does anyone have any idea of what colors to use here?
  2. dream1
    dream1 What's a Dremel?
    26 Feb 2011
    Nice keep going :D
  3. KidMod-Southpaw
    28 Sep 2010
    Paint it exactly the same yellow you used to spray the case. More great progress anyway- well done!
  4. Angel OD
    Angel OD Pump Killer
    16 Sep 2007
    +1 on the same yellow!
    And then maybe a darker shade grey for the "line" and black for the round thingys.
    Thank God for MS Paint:
  5. TheGreatSatan
    5 Aug 2005
    I was thinking maybe black on that long bar and the springs, but everything else yellow...
    Still debating
  6. Wing Zero
    Wing Zero Ita-sha owner
    28 Apr 2010
    This is what i would do. there's more than enough yellow on the case already.
  7. Mosquito
    Mosquito Minimodder
    24 Mar 2011
    That's almost exactly my thoughts :thumb:
  8. l3p
    l3p www.^.nl
    1 Nov 2010
    Love your build :)
  9. TheGreatSatan
    5 Aug 2005
    Everyone I work with likes that too. Maybe I can knock it out tonight.:clap:
  10. TheGreatSatan
    5 Aug 2005
    So, I started painting the treads. First I went all black.
    Then I started the silver.
    I need more exacting brushes, so I'll have to finish tomorrow
  11. RedManc
    RedManc What's a Dremel?
    30 Jul 2011
    I rhink that works quite well although you should have masked the under carrage because that looks like its been painted a bit black, a little preparation would have saved you time here :D unless you intended on doing it in that case its perfect
  12. Wing Zero
    28 Apr 2010
    now quickly, find some spray on mud :D bulldozers are never that clean.
  13. t4n6o
    t4n6o You know when you've been tangoed
    16 Aug 2011
    just a suggestion for the black stripes on the top:
    at the back of the case behind the rivited grill the stripe is at a different level to the rest at the front of the case, maybe to redo that 1 so it doesn't look too out of place?
  14. TheGreatSatan
    5 Aug 2005
    I painted the front undercarriage black
    Then finished the paint on the left side treads. That's all I'm doing on the treads. I think they look best without any yellow.
    More to come
  15. craig - toyoracer
    craig - toyoracer Minimodder
    1 Mar 2011
    A really great theme build going here. Love the louvered side vents very fitting. Nice overall feel to the build. :)
  16. TheGreatSatan
    5 Aug 2005
    Today I received a gift from OCZ.
    And I picked up a fan bus
    And now it's time for some paint
  17. dark_avenger
    dark_avenger Minimodder
    9 Jul 2008
    Looks tasty, how's it perform?
  18. Tangster
    23 May 2009
    Case is looking...functional? :p
    Great job, should be interesting seeing how good the components are as well.
  19. Angel OD
    16 Sep 2007
    Do NOT paint that thing yellow! :lol:
  20. TheGreatSatan
    5 Aug 2005
