Case Mod - In Progress AMD Bulldozer 8-Core Tribute - FINISHED!
Discussion in 'Project Logs' started by TheGreatSatan, 25 Sep 2011.
  1. PlayedStation
    PlayedStation Possessed like an apostrophe
    21 Oct 2010
    Those switches look great, lovely build!
  2. RedManc
    RedManc What's a Dremel?
    30 Jul 2011
    Well said :naughty:
    Is the green plexi on the fanbus not going to look ... odd ?
  3. shrop
    shrop El Jefe of Sleeving
    22 Jul 2011
    Out of interest, looking at that fan controller, the front fascia is held on my Allen-headed bolts, why couldn't you have taken it off, sanded and primed the fascia? Just wondering, it would have looked a bit better in my opinion, it just looks a bit rough and ready.
  4. TheGreatSatan
    TheGreatSatan Dark Lord of BT!
    5 Aug 2005
    It was already brushed aluminum, so I had to only roughen it up enough for the paint to adhere.
  5. shrop
    22 Jul 2011
    But you got those nice acrylic green edges smothered in paint, if you took the front off you wouldn't have!
  6. TheGreatSatan
    5 Aug 2005
    But they're also on the inside case edge. Out-of-site
    Actually, AMD's logo color is green. That's why I'll be backlighting it in green and using green cathodes inside. Maybe even green coolant.... ;)
  7. TheGreatSatan
    5 Aug 2005
    The AMD logo will be going on the right side
  8. lilgoth89
    lilgoth89 Captin Calliope
    12 Mar 2011
    could you not paint those chrome switches black ? i think it would match the paint scheme alot better :)
    amazing project tho, your lucky to have such amazing sponsers :D
  9. TheGreatSatan
    5 Aug 2005
    Actually, I hadn't thought about that. What does everyone else think?
  10. RedManc
    30 Jul 2011
    if you're brave enough to paint the switches go for it my only concern would be that they would get stuck, dont know the best way to attack it :)
    i think the 8 should be blocked rather than rounded.
  11. Maximilian
    Maximilian WC Virgin
    31 Dec 2008
    Nice, very interested in those hybrid revodrives myself, let us know how they are please!
    Great work!
  12. TheGreatSatan
    5 Aug 2005
    So am I. It's getting to the point though where drives are so fast you really can't tell 200MBps from 900MBps
    Here's the parts list thus far:
    Gigabyte 990FXA-UD5
    AMD FX-8150
    16GB Crucial Ballistix
    Radeon 6950
    1TB Revo Hybrid
    850 Watt Enermax 80 Platinum
    Not sure about cooling yet
  13. KiiYzOo
    KiiYzOo What's a Dremel?
    11 Mar 2011
    wow lucky on the parts front
  14. TheGreatSatan
    5 Aug 2005
    My Video card arrived courtesy of Gigabyte
  15. Cheapskate
    13 May 2007
    @Shrop - You are talking to the king of speed-modding there. :D
    I think painting the switches wouldn't work. However, hitting the hardware store for some black rubber boots to fit over them would be good. It would make them black and bulky.
    Bulldozers have shiny bits too -in the hydraulics pistons.
  16. TheGreatSatan
    5 Aug 2005
    Apparently AMD wasn't sure how serious I was about this project and if I had even started yet. So I sent them some pics of my current status. Just got word back this morning that they will be sending me their top processor, the FX-8150!
  17. RedManc
    30 Jul 2011
    Wowzers, looks like this is coming together now with some lovely hardware.
  18. Sheiken
    Sheiken Wat?
    9 Jan 2005
    I am extremely jealous of you right now!
  19. AoE
    AoE What's a Dremel?
    4 Oct 2011
    +1 for the freebie
  20. bagman
    bagman Minimodder
    18 Apr 2009
    That is awesome, when you getting it?
