News AMD Bulldozer to ship ‘within the next week or so’
Discussion in 'Article Discussion' started by Claave, 26 Aug 2011.
  1. Claave
    Claave You Rebel scum
    29 Nov 2008
  2. Paradigm Shifter
    10 May 2006
    If they benchmark well (ie: are a real improvement over the system I have) then I might well think about switching to Bulldozer. Since The 990 chipset supports SLI, it's not like I'll lose Surround, either... :)
  3. play_boy_2000
    play_boy_2000 It was funny when I was 12
    25 Mar 2004
    I'm not convinced it's going to come close to SB, so too much hype can actually be a bad thing for AMD. At this point, I'm all for a early paper launch, just so we can see some hard numbers and put an end to the speculation.
  4. pizzanbeer
    pizzanbeer What's a Dremel?
    19 Jun 2009
    I hope it will be super fast.Time will tell.
  5. Unknownsock
    Unknownsock What's a Dremel?
    13 Jul 2009
    I'd say the Hype has all but gone now tbh...More desperation than anything.
    Although that does depend on performance.
  6. saneblane
    saneblane What's a Dremel?
    19 Jul 2011
    Good, release southern islands too, and kill two birds with one stone
  7. law99
    law99 Custom User Title
    24 Sep 2009
    well if it's as good as the benchmarks we've seen already and a bit better it might be in a purchase list for me. As I can get a board to stick in my phenom and then later chuck in a FX. Otherwise it's going to be a 2500k for my next purchase cpu wise.
  8. Tyinsar
    Tyinsar 6 screens 1 card since Nov 17 2007
    26 Jul 2006
    faster cores > more cores
    I keep hoping AMD will pull it off as I'd like to go back to them for a bit.
  9. thelaw
    thelaw What's a Dremel?
    10 Sep 2010
    So how long after they ship will we see a review or are you releasing the review on the shipping date?
  10. Chicken76
    Chicken76 Minimodder
    10 Nov 2009
    Well, if that were true, Bit-tech would let us know that they received samples for testing, like they did with Sandy Bridge. Since that didn't happen, I'm thinking September 19th remains the most probable launch date.
  11. buttercup
    buttercup What's a Dremel?
    27 Mar 2009
    What's wrong with just calling them modules?
  12. Lazy_Amp
    Lazy_Amp Entry AMD Engineer
    17 Jul 2010
    Unlike Llano which was primarily a embedded part which customers have to make packages for, Zambezi will be getting in end users hands a bit sooner
  13. l3v1ck
    l3v1ck Fueling the world, one oil well at a time.
    23 Apr 2009
    Will there be a full review and benchmarks in the next mag, or will it be the one after?
  14. javaman
    javaman May irritate Eyes
    10 May 2009
    Cause people don't like marketing BS. A spade's a spade
  15. Aracos
    Aracos What's a Dremel?
    11 Feb 2009
    The difference is in this case it's more like a spade is 1.5 spades...so yeah they aren't really the same as cores.
  16. MrTeal
    MrTeal Minimodder
    27 Aug 2010
    I agree, it would avoid some confusion. For instance when I read "ZDNet is saying that each Bulldozer core will have..." I'm wondering if this 'core' refers what AMD is calling a 'core' or what bit-tech is calling a 'core'.
  17. GrahamC
    GrahamC What's a Dremel?
    21 Jun 2006
    Not going to wait for SB-E more money and longer. As I need to invest in new platform for the longer (3years plus) term going Bulldozer. Would like to see info on AMDs new GPUs as well.
  18. The_Countess
    The_Countess What's a Dremel?
    28 Aug 2011
    "a core should be an independent execution unit that can accept, process and output work."
    it has its own scheduler, 4 pipeline's with ALU's AGU's and instruction L1 and half the L1 data cache is reserved for it (its shared yes, but each core has 1 of the way's of the 2-way cache all to itself.)
    so by your own definition its core.
    and i dont see how you can say its one core when its clearly 2 cores that share the a front end. a front-end which in a normal CPU is idle half the time anyway.
    but whether you accept that or not, PLEASE dont call a module a core. just call them a module if you must. otherwise, combined with AMD slides and/or other tech site information we'll end up with people thinking a 8core/4mobule bulldozer has anywhere from 4 to 16 cores on it.
    please dont add extra confusion.
  19. Senilex
    Senilex Not a Troll. Honest.
    11 Dec 2009
    Why do BT continue to try and defy stuff just to be different or controversial. "We are not going to call them modules blah blah blah". I'm sure AMD know more about this architecture and has reason why they are referring them as modules which contains cores than you ill proven knowledge of hardware. I remember when you refused to call the Radeons, AMD Radeons (instead ATI Radeons) just to be idiots - look how that one turned out.
  20. Valinor
    Valinor What's a Dremel?
    30 Oct 2010
    What I remember is that they said they'd start calling them AMD Radeons when the first Fusion APUs came out (they call them APUs, not CPUs), and also that AMD said that they were fine with this.. So why put this point on? It's.. well.. pointless (see what I did there?)
Tags: Add Tags
