Cooling amd chipset water blocks!
Discussion in 'Hardware' started by grritsshawn, 13 Sep 2009.
  1. grritsshawn
    grritsshawn I'm not insane I'm a modder
    20 Apr 2009
    Okay well i just bought a sff case and im gunna water cool it.Here is my question should i water cool the chipsets?AMD 785G, SB710
    if so is ther a single block that i can use that links those 2?
    i would get 2 seperate ones but my shinny new 4870x2 hits the south bridge so if i do 2 seperate blocks no gpu.
    mobo:Gigabyte GA-MA785GM-US2H
  2. Von Lazuli
    Von Lazuli I get by fine with a jig-saw.
    23 Oct 2008
    It is really not worth watercooling the SB, but if you really want to you are going to need to use a separate block. As far as I know, no one has made full board blocks for much other than EX58 boards....
