News AMD demos Zen 'Summit Ridge' CPU performance
Discussion in 'Article Discussion' started by Gareth Halfacree, 19 Aug 2016.
  1. Syphadeus
    Syphadeus What's a Dremel?
    1 Mar 2012
    That's true to an extent - the product should be price positioned relative to where it sits in the market in terms of performance. Thing is, that isn't really how the market works is it?
    Look at a range of Intel CPUs or look at AMD and Nvidias GPUs. Does spending more money guarantee better performance? Does the differential in price between products provide you with insight into the performance differential? I believe the answer to both is no.
    So, whilst Zen shouldn't be cheaper solely because it's AMD and not Intel, it SHOULD be cheaper. Reasons for this are:
    1. AMD does not have the performance / brand prestige that Intel holds
    2. Previous AMD CPUs have over-promised and truly under-delivered
    3. AMD need to poach gamers / enthusiast users from Intel and will need some kind of draw if there is performance parity
    So, if Zen doesn't tantalise on the price front then it's going to have to bring something spanking good to the table else it's just going to wither and die like AMDs CPUs have over the past few generations.
  2. rollo
    rollo Modder
    16 May 2008
    That's the sort of dream hype that does not exist in reality. Expecting a 6900k performing chip for under £300 are we ? AMD can not bankrupt themselves for market share.
  3. Yslen
    Yslen Lord of the Twenty-Seventh Circle
    3 Mar 2010
    Probably will in servers? Depends on power efficiency, though.
