Hardware AMD FX-8120 review
Discussion in 'Article Discussion' started by brumgrunt, 27 Jul 2012.
  1. brumgrunt
    brumgrunt What's a Dremel?
    16 Dec 2011
  2. Harlequin
    Harlequin Modder
    4 Jun 2004
    A question - did you apply both bulldozer hotfixes to windows?
  3. longweight
    7 May 2011
    Oh dear AMD, I'd love it if they could produce something that at least provides a bit of competition for Intel!
    Nice review :)
  4. SMIFFYDUDE
    SMIFFYDUDE Supermodders on my D
    22 Apr 2009
    Intel could go on holiday for 5 years, come back and still be beating AMD's new cpus.
    How old is the i7 920 now?
    Shame seeing the FX brand used on chips like this.
  5. greigaitken
    greigaitken Minimodder
    26 Aug 2009
    saw amd review and thought 'oh dear lets see what they got this time' and clicked on link. Turns out it's still poor little amd cant climb up to the tree house.
  6. Harlequin
    Harlequin Modder
    4 Jun 2004
  7. themassau
    themassau What's a Dremel?
    23 Mar 2012
    acurally in my country a i5 costs as much as a 8150. but i bought the 8120 because it was 50 euros cheaper. alse am3+ motherboards are more higher quality at the same price point. so i bought the saberthoot.
    i also want to learn parallel programming so i could check how it scales at more cores. my previeus cpu was a athlon 6000+ so it feels like an upgrade.
    but i will upgrade again when ddr4 is out en when descent APU's are on the market.
  8. MjFrosty
    MjFrosty Minimodder
    3 Aug 2011
    FX 55, what a CPU that was.
    They need to recruit some new engineers me thinks.
  9. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    It's not the engineers. AMD is using artificially generated CPU Silicon designs, not the original Hand-designed, carefully planned pathways that wound up more efficient and smaller. Which is letting them down in some areas.
    So; I suppose it is the engineers, or at least; the lack of them, which is causing issues like this.
    Bulldozer's Ridiculously long development cycle didn't help the chip. Considering AMD had to take a shot at the future from, what? Six years ago? They've not falling that far off the mark.
    I'm amazed that, for once, A reviewer didn't get a chip that'd do crazy things, though. I can hit 5ghz on this chip. Albiet; not 100% stably. 4.8-4.9 seems to be the ceiling, so far as I've tested.
    I'm never going to hear the end of this review, though. I could break out in the usual "Oh! Cinebench is optimized for Intel chips!" and all that crap, but it wouldn't change the other results. What really ruins the performance in things like the Image Editing is probably the memory speeds. Even the i3 2100 is capable of achieving higher memory bandwidth than the FX 8120.
  10. Harlequin
    Harlequin Modder
    4 Jun 2004
    http://www.insideris.com/amd-spreads-propaganda-ex-employee-speaks-out/
    that italic parts are from 2010 - and the article i linked to is from 2011!
  11. bagman
    bagman Minimodder
    18 Apr 2009
    Intel start to develop their chips 10 years in advance. But you also have to consider that the bulldozer chips were made under a time of uncertainty at AMD with new (was it new CEOs like every month or something because the share holders weren't happy?).
    What I don't understand is how inefficient the bulldozer chips are. 579W @4.65GHz for a chip far from the performance of a i7 920 @4GHz which draws 411W.
  12. Jhodas
    Jhodas Theorist
    4 Nov 2009
    AMD made some weird design choices. Follow this link for a comparison of the X6 1100, X4 980 and FX 8150. The L1 data cache size is smaller on the new FX for a start. (16k vs 64k)
    AMD has also gone for massive 64-way associativity on the FXs L3 Cache. Associativity reduces cache misses, but increases cache latency. Ivy's L1 and L2 cache is 8-way and L3 is 16-way, which appears to be a better compromise (FX 8150 has 4-way L1 data, 2-way L1-instruction and 16-way L2 data).
    Overall, Intel's cache design seems to be simpler and more effective. I think this is one of the main issues Bulldozer has besides the memory controller.
  13. Bkid
    Bkid What's a Dremel?
    27 Jul 2012
    Will be interesting to see, if AMD can make a dual core processor with 4 or 5 GHZ stock speed without any overclocking. Because i'll be the first one to buy it. :)
  14. Hustler
    Hustler Minimodder
    8 Aug 2005
    Still only a Quad Core with some fancy new Hyper Threading thrown in.
    Dishonest marketing from AMD.
  15. Zinfandel
    Zinfandel Modder
    2 Aug 2010
    Why do they even bother?
  16. Harlequin
    Harlequin Modder
    4 Jun 2004
    well if they didnt your fancy new ivy bridge i5 replacement would start at £500 and head upwards.....
  17. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    Their biggest mistake AMD made was to make these new cpu's for a new socket. Instead they could have used it on the AM3 (non plus) and a lot of customers would have bought it as replacement.
  18. tad2008
    tad2008 What's a Dremel?
    6 Nov 2008
    AMD's stuff has certainly been a bit hit and miss over the years and desperately feel the need to upgrade as I am still using an AMD 64 X2 6000+ CPU on the AM2 socket with a mere 2GB ram and a Radeon HD6850 graphics card under XP.
    I had thought of going with AMD's FM1 socket and the Athlon II X4 651K Black Edition CPU til I realised that the FM1 socket is already obsolete and would leave no future upgrade path and simply can't afford the extra layout for an Intel i3 2100 let alone an i5 2400.
    Soo frustrating...
  19. .//TuNdRa
    12 Feb 2011
    Not entirely. Some parts of it are completely doubled. It's more like 1.7 cores per module. It's just the Integer units aren't doubled, which means Bulldozer Tanks in any mathematical tests that stress more than four cores.
    Chip production issues. This current batch are very, very badly produced. Bulldozer would have been much better if it didn't have this much in the way of silicon leakage. The new Stepping AMD is planning to roll out at some point (Although I'm not sure if that's been canned in favour of Piledriver) is said not to have as bad a case of these issues, but I don't hold much hope.
    I'm committed now, with the amount of money i've sunk into this, and I will fight tooth and nail to prove that it's not crap, but I'm never, ever going to claim it's the best, or anywhere near.
  20. Action_Parsnip
    Action_Parsnip What's a Dremel?
    3 Apr 2009
    There is no B3 stepping of Bulldozer coming. The next version will be the piledriver version.
Tags: Add Tags
