News AMD, IBM develop 45nm high-k metal gate transistor
Discussion in 'Article Discussion' started by Da Dego, 30 Jul 2007.
  1. Da Dego
    Da Dego Brett Thomas
    17 Aug 2004
  2. kenco_uk
    28 Nov 2003
    What's needed is a picture of the tip of a biro or something similar to accentuate the sheer smallness of the transistor. For all I know, my cpu could be filled with a billion fluffy bunnies.
  3. completemadness
    completemadness What's a Dremel?
    11 May 2007
    the tip of the biro would engulf the whole image i believe - maybe a human hair could be put next to it ...
  4. FIBRE+
    FIBRE+ Minimodder
    27 Feb 2005
    From which area of the body?, as they normally differ in thickness.
    Lets play Higher or Lower :idea:
  5. Nature
    Nature Minimodder
    21 Nov 2005
    The article "logical conclusions" could link it's story to this news of new innovation from intel&IBM, AMD is getting around the corner, whilst intel has nerd scouts for high schools.. They invest so much in their "creative recruitment" and development.
    Inel has merely reinvented the Pentium M.... and now shrinking it.
  6. hitman012
    hitman012 Minimodder
    6 May 2005
    A biro tip is too large. They're usually 1mm or so in diameter, so you could fit about 45,000 gates in a line over the visible part of the ball tip. The width of a typical human hair is about 80 µm, making it a bit better for comparison. The gate is 45 nanometres across, making them about 1800 times smaller than that. Here's a rough diagram (it's a large image so that the 2px transistor is visible).
    The transistor is obviously larger than just the gate but it gives you an idea of the ridiculous scale involved.
  7. Guest-16
    Guest-16 Guest
    You're talking nanometers, and human hairs are far far larger still. Remember it's HUNDREDS OF MILLIONS in the space of your fingernail, and you're seeing only part of one in that picture.
  8. Joeymac
    Joeymac What's a Dremel?
    3 Oct 2006
    The other way round to do the comparison is how big would a chip be if the gate or the transistor was the size of a smartie or something.
  9. kenco_uk
    28 Nov 2003
    Holy crap, that's quite small.
  10. hitman012
    6 May 2005
    The die size of these 45nm chips is apparently going to be 107 mm2. If the gate was the size of a Smartie, then your Smartie processor die would have an area of be 107 mm2 * (1.1cm / 48nm)2 = about 5.6 million m2 (5.6 km2). Take your pick, but that's either 21,000 tennis courts, 4500 Olympic-size swimming pools, 900 football pitches, or 22 times the floor area of the Empire State Building.
  11. Joeymac
    3 Oct 2006
    I think the word required here is.... "blimey".. or something to that effect.
    So when they design a processor, without any of the actual "designing it" or making it work, just the shear leg-work, it is the same as sorting and lining up enough smarties to cover 21,000 tennis courts! Wowzer!
    Thanks for doing the sums :D
  12. Xir
    Xir Modder
    26 Apr 2006
    Sorry, quoted wrong.
    New post below
  13. Xir
    Xir Modder
    26 Apr 2006
    Yes, and then connecting them in 3-D over 9 layers :D
    Cheers,
    Xir
Tags: Add Tags
