News AMD introduces ATI Radeon HD 4830 graphics card
Discussion in 'Article Discussion' started by Tim S, 23 Oct 2008.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. badders
    badders Neuken in de Keuken
    4 Dec 2007
    So.... You got an unintentional Radeon 4810 then?
  3. mclean007
    mclean007 Officious Bystander
    22 May 2003
    Do you mean only seven were enabled i.e. 3 were disabled, as opposed to 8 being enabled and 2 disabled as should be the case, giving the proper SP cound of 8*5*16 = 640 compared to 10*5*16 = 800 on the full fat 4850 and 4870?
  4. Tim S
    Tim S OG
    8 Nov 2001
    Thanks, you're right - brain fart. :)
  5. Cupboard
    Cupboard I'm not a modder.
    30 Jan 2007
    oops. Rather an odd thing to happen unless they are, as Badders suggests, releasing something else based on the RV770
  6. ZseLotH
    ZseLotH What's a Dremel?
    15 May 2008
    Might be my next buy when I see full benchmarks and get money... GJ ATI/AMD
  7. docodine
    docodine killed a guy once
    10 Feb 2007
    Not worth the price, at $20 less than the cheapest 4850.
    If it goes under $100, maybe.
  8. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    I saw this on the techpowerup review as well. It is odd although one saving grace at least from the TPU review is the fact that the 560stream card overclocks like it has a hundred weight of wusabi (sp?!) up its backside.
    On another note OCUK and ebuyer have these up for preorder for £99.99 which quite frankly is an absolute rip off. It is only £10 cheaper than the HD4850 (and if you look around it isn't cheaper at all). Why you would choose one of these (at the current pricing) over a HD4850 (or even a 9800GTX+ which I have seen for £99 as well) is beyond me.
  9. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    i think they fixed it already...
    "How to Fix
    Added: Oct 24, 2008
    Grab this BIOS from our VGA BIOS Collection and flash it to the card using WinFlash or ATIFlash.
    This BIOS is designed for the AMD reference design samples that were sent out with 560 shaders, there is no reason to flash it on cards from other manufacturers that already have 640 shaders. "
Tags: Add Tags
