News AMD launches HD 2600, 2400 series
Discussion in 'Article Discussion' started by Tim S, 28 Jun 2007.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. BioSniper
    BioSniper Minimodder
    5 Feb 2002
    Are you looking to buy a mid-range DirectX 10 card?
    Only after bit (hopefully) does a round up review :thumb:
  3. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    quickly now..... benchmark them all!!!
  4. Hugo.B
    Hugo.B What's a Dremel?
    4 May 2007
    I don't care about DirectX 10, but since I have an nVidia card, I'd like to try AMD next, so it's useful to know about the card before hand.
    H.B.
  5. trig
    trig god's little mistake
    10 Aug 2006
    not that im buying one, but i cant find them anywhere...
  6. Amon
    Amon inch-perfect
    1 Jun 2007
    No mention of the 1GB 2900 XT using the same GDDR4 chips?
  7. C-Sniper
    C-Sniper Stop Trolling this space Ądmins!
    17 Jun 2007
    ATi Drivers suck so my next GFX card will probably be an Nvidia unless AMD/ATI overhaul their Drivers/catalyst.
  8. Tim S
    Tim S OG
    8 Nov 2001
    I've been waiting for one since before Computex...
  9. Amon
    Amon inch-perfect
    1 Jun 2007
    Is it a supply problem or sponsorship issue? They're widely available in Canada already, so, if you are lacking supply, I'll just buy one here and then ship it to bit-tech.
  10. Gravemind123
    Gravemind123 avatar not found
    26 Aug 2006
    Having seen some 2600XT and 2400XT benchmarks from Anandtech, they are apparently weaker then the 8600s in every DX9 game they tested with the exception of Rainbow 6: Vegas where the HD 2600XT was close to the 8600GTS. Sort of depressingly low performance especially the 8600s have been considered to be underwhelming in performance.
  11. keith_j_snyder2
    keith_j_snyder2 What's a Dremel?
    22 Apr 2006
    It might be Drivers problem.Have u seen those benchmarking results on inquirer when they used 2X8800 GTX in SLI and they benchmarked Rainbow Six Vegas which gave only 40 FPS?
    I think the same is here!
  12. Guest-23315
    Guest-23315 Guest
  13. keith_j_snyder2
    22 Apr 2006
    Yes i also saw that but do u really think that it has some juice?
  14. Amon
    Amon inch-perfect
    1 Jun 2007
    It certainly does. The high-end 1GB 2900 XTs come with their core and memory frequencies overclocked by default. It can put up a very good fight against an 8800 GTX 768MB. Recently, Falcon Northwest released their newest flagship Mach V whose dual 1GB 2900 XT package crushed their previous dual 8800 GTX configuration.
Tags: Add Tags
