Build Advice AMD "Lynx" APU Based System
Discussion in 'Hardware' started by mattyh1995, 22 Jan 2012.
  1. mattyh1995
    mattyh1995 Minimodder
    1 Oct 2011
    I'm putting together a budget tower together for a friend, came up with this. Best I can think of for >£400, which is his upper limit.
    CASE: Silverstone Precision PS04B - £29.63
    CPU: AMD A8-3870K Black Edition - £107.75
    MOBO: Gigabyte GA-A55M-S2HP - £55.86
    RAM: 4GB (2x2GB) Corsair DDR3 XMS3 -£21.79
    HDD: 500GB Seagate ST500DM002 - £64
    PSU: 530W PSU, Be Quiet Pure Power - £45.04
    ODD: Random Samsung drive - £13.55
    TOTAL: £337.62 from Scan.co.uk without ScanSure and delivery charges.
    That PSU is so he can get some upgrade in at a later date, like a dedicated GPU. Anywhere where money could be saved so I can fit something like a HD6770 in there?
    For some gaming in low settings, at a lowish resolution (I don't know exactly) would this do well?
    I don't have experience with "Lynx" APU's.
  2. KidMod-Southpaw
    28 Sep 2010
    The APU will be fine for even mid resolution gaming, so there shouldn't be a need to put a 6770 in there anyway. Read Bit Tech's review of the APU, you'll see.
  3. mattyh1995
    1 Oct 2011
    Okay :) and the HD6770 was a sort of "extension" option to get another year out of it ^^
  4. murraynt
    murraynt Modder
    6 Jun 2009
    You might be better off with an intel i3 2100 and maybe a second hand 460 gtx?
  5. mattyh1995
    1 Oct 2011
    I might, but I want all new. And plus an APU + Discrete GPU is supossed to be quite good ^^
  6. meandmymouth
    meandmymouth Modder
    15 Sep 2009
    The APU will overclock quite nicely also. I got the 3670K for a friend when it was on a nice deal and it was a surprisingly little chip! The CPU cores clocked nicely as did the GPU cores.
    I'm not an AMD fanboy but I love the APU's.
  7. Jipa
    5 Feb 2004
    I have an APU-setup and it really surprised me! I have the A75-UD2H board and the 3850-chip and it's such a versatile little platform...
    I've also had the HD5- and HD6-low end cards around and personally I wouldn't bother. If he really needs more gaming performance than the APU provides, he's going to need something better than the low-end cards anyway, as the difference between those seems so small. (EDIT: WHOOPS I suppose the HD6770 is a genuine upgrade, I was thinking about the HD6570 and 6670)
    I would tell him to stretch the budget another £20 or so and get 2*4 GB of memory, because that will really help!
  8. mattyh1995
    1 Oct 2011
    Can the 6670 do crossfire with the built in 6550D? I'd like him to be able to play a decent game with me for once ^^
  9. debs3759
    debs3759 Was that a warranty I just broke?
    10 Oct 2011
    I read somewhere earlier today that you can use an HD6670 or HD6770 in crossfire with the built in HD6550D. I was checking because I have an A8-3870K coming soon and already have an HD 6770 I can put with it :)
  10. mikeyman198
    mikeyman198 Lets pretend this is hilarious.
    12 May 2011
    Yep the 6770 is the highest end GPU you can use alongside the 6550D :)
  11. mattyh1995
    1 Oct 2011
    Hmm. After posting that I did some googling and people say that the 6670 is the best you can use with it
  12. mikeyman198
    12 May 2011
    It appears you are correct, dunno why I thought it was the 6770 :p
  13. mattyh1995
    1 Oct 2011
    M'kay. Settled it, I'm getting him the system from above with a 6670 included ^^ He'll appreciate that.
  14. debs3759
    10 Oct 2011
    http://www.pureoverclock.com/review.php?id=1427&page=9
    They say 6770 is the best, but it will downclock to act as a 6550.
    EDIT:
    I did some more checking, and that site seems to be the only one that says 6770 will work. Looks like my IGP will be a physx processor once I'm done with benchmarking it :)
