AMD Mobile 2500 or 2600?
Discussion in 'Hardware' started by DaHoboFest, 30 Aug 2004.
Thread Status:
Not open for further replies.
  1. DaHoboFest
    DaHoboFest Banned
    7 Aug 2004
    I don't think I can change the voltage, but I read reviews on newegg.com about the 2500 and the 2600 mobile, they both said they oc very well. I want it atleast at 3200 speeds. However, I can't up the voltage. I will have a thermaltake volcano 11 on it. What can oc to 3200 speeds easilier with regulard voltage?
  2. olv
    olv he's so bright
    23 Sep 2002
    Default volted for the mobile chips is 1.45v, thats pretty low for a decent overclock. If you get a decent stepping then you'll possibly manage 2.2-2.3ghz on stock volts. maybe a little bit more. I know my mobile 2500 hundred needs 1.75 (BIOS) 1.7 actual to be prime stable at 2.4ghz 200x12.
    If you are serious about overclocking then you really need a new motherboard. If you keep the same board make sure that it supports mobile athlons.
  3. DaHoboFest
    DaHoboFest Banned
    7 Aug 2004
  4. message2harry
    message2harry What's a Dremel?
    31 Aug 2004
    i have a mobile 2500+ and for sum reason i can o/c to 2.5 ghz with crappy pc2100 512mb ram and default volts...... MAKE SURE YOUR MOBO CAN CHANGE MULTIPLIERS I GOT A BRAND NEW ABIT NF7-s2 AND FIGURED OUT THAT THE POS DOESNT EVEN HAVE MULTIPLIER ADJUSTS SO I CANNOT EVEN SET IT AT STOCK SPEEDS!!!!!! my old gigaybte does just fine though mm hmmmmmm gigaybte...... mmmmmmmmmmm hmmmmmm
  5. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    That was the mistake
    you need the V2.0 not s2. Thats the new board without Multi adjustements, and they added gb lan or some crap.
    Anyways, back OT, both of those chips should do 3200 on or very near stock voltage. However a new mobo would be a good idea IMHO.
  6. DaHoboFest
    DaHoboFest Banned
    7 Aug 2004
    I don't have multiplayer, but I can change the fsb utp 200 I think. But wil the mobile 2500 or 2600 fit in my socket a? link to mobo above.
  7. TMM
    TMM Modder
    12 Jan 2004
    Yes it will fit in your socket, but your screwed without a multi. Mobiles default to 5 or 6 multi becuase the desktop mobo won't know what clockspeed to run it at.
    Your going to need to change this to run at default and o/ced speeds (default multi is about 13 iirc)
    [​IMG](why , i am using this alot lately :D)
    2.5 at default volts? get real m8 :hehe: you'd be lucky to hit 2.2stable at default (1.45) volts.
  8. dead_man
    dead_man Confucious say: WTF???
    4 May 2004
    i dont think its gay, i use the 7n400 pro2 rev2.0 i think its a sweet board, especially since i can overclock this thing more then me mates a7n8x-e :D and that using the same CPU and ram
  9. DaHoboFest
    DaHoboFest Banned
    7 Aug 2004
    with my mobo, would I be able to atleast oc to 200 fsb (3200) with stock voltage? Also, which hsould I get 2500 or 2600?
  10. message2harry
    31 Aug 2004
    (why , i am using this alot lately )
    2.5 at default volts? get real m8 you'd be lucky to hit 2.2stable at default (1.45) volts.
    __________________
    watever man, tell me how to post pics and ill prove to you i run it at STOCK VOLTS, STOCK TIMINGS, except 200 fbs. I was as dumbfounded as you my friend.
  11. message2harry
    31 Aug 2004
    by the way its cooled by danger den maze 4 blocks
  12. message2harry
    31 Aug 2004
    O AND MY MULTIPLIER is at 12.5, lower as u can imagine so its more fsb o/c
  13. ric449
    ric449 What's a Dremel?
    7 Mar 2004
    Ok, take a screenshot of the o/c with the print screen button (a screenshot of CPU-Z would be fine). Then, upload it to this place:
    www.imageshack.us
    It should be easy to figure out. Then, when it gives you a list of things you can cut and paste to put your image on the internet, copy the one with the [​IMG]
  14. Carbon
    Carbon Banned
    8 Jan 2003
    2500 + Infinity + Sp-97 + Bios Saviour = [Insert picture regarding sexual intercourse] :blush:
  15. message2harry
    31 Aug 2004
  16. message2harry
    31 Aug 2004
    damn thats blurry lemme try again...
  17. ric449
    7 Mar 2004
    I don't see anything about the memory though... Download CPU-Z, click the memory tab, and take a screenshot.
  18. message2harry
    31 Aug 2004
  19. DaHoboFest
    DaHoboFest Banned
    7 Aug 2004
    instead of fighting aboug ocs please answer my question, which is better 2500 or 2600? Which wil oc to atleast 200 fsb easilier at stock voltages? Does it have to be mobile? Regular is cheaper.
  20. Highland3r
    25 Jul 2003
    Both are ~ the same.
    Both should do 200 fsb no prbs.
    yes, needs to be mobile, they clock better and have unlocked multis.
    Can you post a CPU-Z screeny please, along with the mem section AND ~ 5 hours of prime :D
    Anyone can take a death screeny... not saying you are but just to show you arent :D :thumb: :thumb:
Thread Status:
