Hardware AMD Phenom X4 9350e - 65W quad-core
Discussion in 'Article Discussion' started by Tim S, 24 Jul 2008.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. DougEdey
    5 Jul 2005
    Odd question: How would this cope in a laptop/notebook setup? Would it be a huge drain on battery life, too much to make it worthwhile, or would it not significantly increase the power assumption but give rise to a good quad core portable?
  3. Guest-16
    Guest-16 Guest
    65W is too much for a notebook imo.
  4. DougEdey
    5 Jul 2005
  5. Guest-16
    Guest-16 Guest
    Yea, P4s!! My mate had one and his notebook was an inch thick with a 30 minute battery life.
  6. DougEdey
    5 Jul 2005
    Remember though, batteries have improved a lot since then, and this one is 75% lower TDP, so theoretically, you'd get 40 minutes!
  7. mrb_no1
    mrb_no1 Pie Eater
    15 Sep 2007
    damn amd, seems like another waste of time....
  8. Mo_
    Mo_ Did this world come by chance?
    7 Apr 2008
    Another flop from AMD - they are the flopmasters
  9. M4RTIN
    M4RTIN What's a Dremel?
    11 Sep 2006
    who needs a quad core home theatre? never had to do any serious number crunching while watching a dvd before...
    this looks like your choice is, do four things really slowly or you can do two things really quickly with a much cheaper athlon64 .. maybe it averages out in the end..
    btw when are the 45nm phenom's out
  10. Guest-16
    Guest-16 Guest
    It's not DVD playback - you can do that on a VIA EPIA! The IGPs on those have MPEG-2 acceleration.
    If you're playing 1080p h.264 rips and you aren't using something like a 780G/8200 IGP, then a 9350e + CoreAVC codec = win! Unfortunately I don't have a 5400+ 2.8GHz 65W dual core to test either, but a 2.5GHz dual core wouldn't do it and we loaded all four cores 30-40% on the 9350e.
    This CPU is a niche product for a specific application, that's all.
  11. azrael-
    azrael- I'm special...
    18 May 2008
  12. Guest-16
    Guest-16 Guest
    Yup, just what we though, except we don't have a 9550 to test :(
  13. azrael-
    18 May 2008
    Are those comparative Phenom 9550 scores in the article from an earlier test scenario?
    Still, the 9350e is a nice enough processor for what its meant for. AMD just shouldn't sell it at a price premium compared to the otherwise identical 9550.
    I'm more worried about those other findings at Anandtech. Namely that the Phenom seems to have problems getting out of Cool'n'Quiet mode properly. I hope this is fixable via a microcode update.
  14. Guest-16
    Guest-16 Guest
    The 9550 results were a clocked down 9850. I'd only want to test a true retail sample to do a more sensitive comparison though.
    We found the same as Anand - CnQ basically sometimes doesn't come out of it (Sony Vegas, or Prime95) even when the CPU is loaded. I think it's a driver issue although others blame Vista thread handling and power management.
  15. eek
    eek CAMRA ***.
    23 Jan 2002
    The front page mentions "9530e" a couple of times, should it not be 9350e?
  16. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    i must say, when the next generation of laptops comes along with Quad cores, then i shall upgrade my now aging laptop which was purchased in either 2005 or 2006 and has recieved a few upgrades since then. the Dothan is still a powerful CPU, wish it was a Yothan.
    still looking at sub-notebooks, but my work is graphic intensive...:waah:
    I really want AMD to knock out a decent CPU, iv been a fanboy for along time, cough K6-II. But intels price and performance was just a common sense purchase no matter how much i love AMD.
  17. Amon
    Amon inch-perfect
    1 Jun 2007
    Bit-tech still hasn't fixed the colour key to their PCMark Vantage charts.
    Those notebooks were accompanied by up to 105-watt external power bricks. The reality is that 95% or more of all notebooks worldwide are available with a 65-watt brick, only.
    Give AMD some good, hardcore German porno and you can be sure they'll knock more than one out.
  18. Guest-16
    Guest-16 Guest
    Fixed, twas me typoing
    True, next time I'll redo the whole lot separately.
  19. dk-melgaard
    dk-melgaard What's a Dremel?
    1 Aug 2008
    should be perfect for media centers:p but again.. wich media center needs a quad core xD
  20. punisher0276
    punisher0276 What's a Dremel?
    4 Aug 2008
    The board used for the Phenom is a piece of crap. The sb is 1000 and fails to give a true test of the fsb. The full fsb is 2600 and ht is 6200 on good amd boards with either chipset. I personally use a 750a MSI with 8800 gt sli and get close to 50 fps with a 9950. I use OCZ 1066 ram 4gb as well. If you test with crap you get crap. I have 2 systems with wolfdales and they are fast but the 8800 ultra is outdated. You think they would have used a GTX 260 or 280 by now or even a 9800 GX2. The quad cores listed mostly get the same or worse frame rates unless you go to a 9450 or core extreme you can forget it. In fact unless you are at 2.6 ghz you can forget it period. Crysis is a rough hardware game period. I switched from a 9600 phenom to a 9950 and added over 20 fps with the same board and ram. Clockspeed is everything in sli. My choice of the 2.6 phenom with a decent board was great and now I am getting a GTX 260 for hybrid sli. My sons enjoy their wolfdales and for the price they make the q6600 a waste of time. In fact I wouldn't go lower than a q6700 in an Intel quad for this game after multiple systems and testing on my own.
Tags: Add Tags
