AMD Phenom x6 PPD?
Discussion in 'bit-tech Folding Team' started by enigmo, 11 May 2011.
  1. enigmo
    enigmo Kettleboiler Extraordinaire
    13 Apr 2010
    Morning all,
    Anyone have any idea how many ppd I could expect from a Phenom II 1090T @stock (3.2GHz)? It's been a few years since I'd considered an AMD rig, but six cores and decent PPD could persuade :)
  2. enigmo
    13 Apr 2010
    Actually, scratch that. If it can't do bigadv then it's another pointless upgrade.
  3. Christopher N. Lew
    Christopher N. Lew Folding in memory of my father
    23 Apr 2009
    8000 - 10000 PPD
  4. Haphestus
    Haphestus ....the folding under dog
    29 Jan 2010
    cant you OC it and run Bigadv?
  5. Christopher N. Lew
    23 Apr 2009
    -bigadv requires 8 cores (real or virtual), regardless of their speed.
  6. TaRkA DaHl
    TaRkA DaHl Well-Known Member
    15 Mar 2011
    You can run bigadv on a x6.
    Just need to use VMware and have a linux image running, tell the image to provide it with 8 cores and you need around 0.5Gb of ram free per core. So 4Gb plus enough to run the linux image plus enough to run XP/7 or whatever the host is.
    It is cheating, and not supposed to be done. But it does work.
  7. Haphestus
    29 Jan 2010
    VMware for folding........now were talking!!!
    Artificial hyper threading Cheesecake!!!!
    :D
  8. Haphestus
    29 Jan 2010
    Where did cheesecake come from??
  9. fir3x
    fir3x fir3x
    18 Jun 2010
    shhhhhh, you need a NDA on your ass lol
  10. TaRkA DaHl
    15 Mar 2011
    :D
    Hopefully going to try this with my i5 2500k tonight if I have time, interested to see if it can complete the WU's in time. Should do at 4.8Ghz :p
  11. enigmo
    13 Apr 2010
    That's actually not bad. More than all my current gpu folders combined...
  12. enigmo
    13 Apr 2010
  13. TaRkA DaHl
    15 Mar 2011
    It is possible, you need to setup a VM image of linux (ubuntu) and force it to use 4 cores, then when in Linux you need to use Wine to run the normal 6.34 FAH.exe. You can then create a custom config file for wine to force it to run the emulation with 8 cores rather than 4/6 :p
    You will need a pretty high OC with an x6 to complete them, probably 3.6-3.8Ghz...
  14. coolamasta
    coolamasta Folding@Home CC Captain 2010/11/12
    26 Apr 2009
    Where have you seen this done out of interest, any links?
    People with a 6 core CPU's still need to set the VM to use 4 cores, or 6?
    I didn't think this worked so I am intrigued now :geek:
  15. TaRkA DaHl
    15 Mar 2011
    No links, did it myself last night lol.
    Initially I used my dual boot with Ubuntu LTS (10.04i think..) and used Wine to run the standard windows 6.34 client. You need to make a few modifications to make wine tell the program you have more cores.
    What I ended up doing was booting Win7, creating a Ubuntu VM with all 4 cores used, then used Wine to run the Windows6.34 FAH.exe file with a wee modification.
    I had a colleague that used to have to do something similar to this with an old server side program that required you had 8 cores, he only had a 4 core machine but it was quick so he managed to spoof it to run and it worked fine. Same principal here. Will grab the code and step by step stuff when home tonight if you are interested.
    You will need a pretty heavy OC with an x6 to do this, same with an i5 2500k. Probably 3.6Ghz-3.6Ghz for the x6 and 4.5Ghz for the i5 I recon.
  16. meandmymouth
    meandmymouth Well-Known Member
    15 Sep 2009
    I get up to 13k PPD at 4GHz on my 1090T so 8000 - 10,000 sounds about right at stock
  17. Tattysnuc
    Tattysnuc Thinking about which mod to do 1st.
    19 Jul 2009
  18. meandmymouth
    15 Sep 2009
    Thanks for that, may come in handy!
