News AMD prices Threadripper parts, outs Ryzen 3 specs
Discussion in 'Article Discussion' started by bit-tech, 13 Jul 2017.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
  2. Wakka
    Wakka Yo, eat this, ya?
    23 Feb 2017
    So you can get a 12c/24t 1920X + TR4 board + spare change for less than 10c/20t 7900X on it's own?
    Good luck Intel, you need it.
  3. Guest-16
    Guest-16 Guest
    $200 TR4 will be very entry level.
  4. Wakka
    23 Feb 2017
    True, but just like how you don't need a top-end X370 board to get the most from Ryzen, I suspect there will be more "value" options with X399 than X299.
  5. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    Are the specs for the R3 a typo? It says 4 cores 4 threads, shouldn't it be 8 threads.
    Ignore ^^that^^ as i just remembered the R3 has SMT disabled.
    Also does anyone know if there's been any more info on the rumors that the R3 would still use two CCX's.
  6. Gareth Halfacree
    4 Dec 2007
    Nup: only the Ryzen 5 and above families have two threads per core; the Ryzen 3 is exclusively one thread per core. Both Ryzen 3 chips announced thus far are four core, four thread just as the article says.
    Corky42 likes this.
  7. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    Wow so I can get a 12c/24t TR for the same price as Intel's 8c/16t 7820X ...
    Nice! :)
  8. Gareth Halfacree
    4 Dec 2007
    Aye - and at that point, assuming your workload threads nicely (and if it doesn't why the heck are you buying a many-core processor), the AMD chip can have way lower per-core performance and still best the Intel chip every single time.
    Exciting times, these. Exciting times.
  9. GravitySmacked
    GravitySmacked Mostly Harmless
    2 Mar 2009
    Now there's a influx of multi-cored CPU's I can't wait for more software to start making use of all the cores. At least the incentive is finally there.
  10. Anfield
    Anfield Multimodder
    15 Jan 2010
    The 7820X is £530 inc vat, the 12c TR is £618 without vat. Of course with 4 more cores and 36 more pci-e lanes that is still good value if you have a use for that kind of performance.
  11. TheMadDutchDude
    23 Aug 2013
    Long live AMD. They're here to stay and play ball. :D
  12. Wakka
    23 Feb 2017
    That's why I compared it to the 7900X, where the value goes into the stratosphere...
  13. wolfticket
    19 Apr 2008
  14. rollo
    rollo Modder
    16 May 2008
    Cya in 3 years when you can use a 16 core 32 thread cpu in the desktop work space. £1000 is still a horrible price to pay for a cpu no matter who manufactures it, Its resonable compared to what Intel charges sure. Are you buying one cause its so reasonable?
    AMD also have a problem that they made, There EPYC 7401P 24c/48t CPU is about $1075 with more cores better memory support and a better more stable motherboard for the work its aimed at. Why would you buy a $999 threadripper when you can buy a EPYC with 8 more cores and 16 more threads for $75 more.
  15. Anfield
    Anfield Multimodder
    15 Jan 2010
    Because of the low clocks of Epyc, 7401P:
    Max Turbo Core Speed
    3GHz
    All Core Boost Speed
    2.8GHz
  16. xaser04
    27 Jun 2008
    I stand corrected on the price. I do recall that the price was higher a couple of weeks ago but maybe I have had a brain freeze after so many Treasury Management system meetings this week...
  17. rollo
    rollo Modder
    16 May 2008
    3.4ghz is hardly a big jump and if your buying these cpus your work is going to be highly multi threaded where the clock speed matters very little.
    Clock speeds will only really matter below a certain core work stack, Intel Xeon are usually below 3ghz and sometimes even closer to 2ghz.
    It will be interesting to see the bench figures, AMD loves cinebench mark, let's see the 2 compared my feelings EPYC will destroy threadripper.
  18. Anfield
    Anfield Multimodder
    15 Jan 2010
    With properly threaded workloads like Corona render and such Epyc will no doubt slaughter Ripper, the problem will be what percentage of software that a prospective buyer uses that scales beyond how many cores.
  19. rollo
    rollo Modder
    16 May 2008
    I would suggest that applies to most software in usage today, what % of software even supports 8 cores properly that are not benchmark tools.
    I feel like if you need 16 cores you probably want even more. For $75 more it's a easy decision considering it will be the cheapest bit of the build.
    128gb ecc ram is like $3k.
Tags: Add Tags
