News AMD Project Discovery tablet images leaked
Discussion in 'Article Discussion' started by Meanmotion, 15 Nov 2013.
  1. Meanmotion
    Meanmotion bleh Moderator
    16 Nov 2003
  2. Harlequin
    Harlequin Modder
    4 Jun 2004
    AMD have said they wont be making any hardware themselves its just a prototype for the new APU.....
  3. Guinevere
    Guinevere Mega Mom
    8 May 2010
    I think you mean it offers a 39% improvement.
    0% improvement means it's no better.
    100% improvement means it's twice as good.
    139% means it's 2.39 times as good.
  4. Meanmotion
    16 Nov 2003
    What, like it says in the article? ;)
  5. meandmymouth
    meandmymouth Modder
    15 Sep 2009
    Shame. The images look good and I see no reason why they shouldn't lead from the front with their own technology.
  6. Guinevere
    Guinevere Mega Mom
    8 May 2010
    And surely it's not a prototype if they're not going to build the darn things. Maybe you mean concept device? Or reference design if you want to push the definitions.
  7. Meanmotion
    16 Nov 2003
    Nope, 139% is what AMD is claiming.
  8. dyzophoria
    dyzophoria Minimodder
    3 May 2004
    that actually looks sexy
  9. Meanmotion
    16 Nov 2003
    Only if you choose to define prototype in a very restrictive manner. While, yes, a reference design would perhaps be a more accurate summation, it is still a first attempt, a proof of concept for the industry.
  10. azazel1024
    azazel1024 What's a Dremel?
    3 Jun 2010
    It is a 139% better performance per watt, based on TDP of the chips and performance improvement. Which is a little specious, since actual power consumption underwork load for Temash versus Mullins at which the performance is obtained is not specified nor is the measurement at that.
    A lower TDP doesn't necessarily mean a lower SDP.
    Anandtech does have the break down in performance increase and it is roughly in the 30% range for increased CPU performance and 20% for increased GPU performance of Mullins versus Temash.
    AMD is also claiming around a 2x increase in performance per watt.
    By comparison Bay Trail scores about 65% of what Temash does in 3dmark11 (or about half of Mullins), but about double what Temash can manage in PCmark. Which makes Bay Trail more than 50% faster on the CPU end than Mullins. GPU lags a lot, but the CPU is still way ahead.
    In normal use, the CPU being so weak is what you are much, much more likely to notice at the performance levels we are talking about.
    Also Cherry Trail, Bay Trails replacement, which will be coming out roughly in the same time frame as Mullins, so looking likely to have roughly a 50-100% increase in GPU performance over Bay Trail...which means that Cherry Trail is likely to have a MASSIVE CPU performance lead and probably be somewhere between 80-120% of the performance of Mullins in the GPU department.
    Probably also while consuming less power.
    If Mullins was here TODAY, it might make an interesting comparison to Bay Trail. It will be going up against Cherry Trail though (in all likelihood).
  11. fluxtatic
    fluxtatic What's a Dremel?
    25 Aug 2010
    Once anyone other than Intel uses SDP, that's when I'll start to care.
  12. maverik-sg1
    maverik-sg1 Minimodder
    18 Aug 2010
    Outside of synthetic benchmarks I am weary of comments where the cpu is slow etc.....
    Compared to it's peers that may be the case, compared to the programs it has to run smoothly, if it's capable of doing that, I don't see this being a reason not to buy. Having more GPU grunt and tying some of that parallelism into a shared CPU resource, assuming the code is written correctly, then it could even be better in certain situations.
    I am more concerned of the crappy codenames for these products Cherry Trail and Mullins, sounds more like a new TV series than an exciting new chapter in mobile computing.
  13. rollo
    rollo Modder
    16 May 2008
    Could be another nvidia shield style thing.
    Competing with Microsoft for 3rd place in tablet market sounds like a recipe for disaster though.
    Gl to them.
  14. azazel1024
    3 Jun 2010
    AMD is now using SDP, apparently.
Tags: Add Tags
