News AMD Quad Core CPUs arrive in August
Discussion in 'Article Discussion' started by Da Dego, 29 Jun 2007.
  1. Da Dego
    Da Dego Brett Thomas
    17 Aug 2004
  2. Techno-Dann
    Techno-Dann Disgruntled kumquat
    22 Jan 2005
    Looking forward to this... I'm planning my next system to be a drop-in upgrade to an AM2+ Barcelona.
  3. RedDethX
    RedDethX New Member
    23 Jan 2006
    Awesome!:D
  4. coniferous
    coniferous What's a Rotary Power Tool?
    9 Jun 2007
    I'm really hoping that more games become multi threaded, I know its not straightforward for the programmers - but if processor development keeps on heading in this direction...
    I thought AMD was creating a technology where it would figure out a way to let one thread's math be spread accross two cores? Was i loosing it?
  5. teamtd11
    teamtd11 *Custom User Title*
    31 Aug 2005
    A new AMD chipset motherboard, then 1 of these babys. i can't wate:cooldude:
  6. Buzzons
    Buzzons Active Member
    21 Jul 2005
    surly comparing the opterons to the C2D range is a bit stupid? it should be compared to the clovertown xeons (Xeon 53XX) series, which are already quad core etc etc, as well as the upcomming (when ever it is??) release of the one after clovertown based around the 45nm core and on die memory controller (much like the new Itaniums from intel)
  7. Amon
    Amon inch-perfect
    1 Jun 2007
    Now I have got to see Barcelona's performance claims substantiated in the enterprise world. AMD's primary market, it appears, is the server market. If the Barcelona is as big of a success as Sledgehammer and Barton (oh, we remember the wildfire popularity they caused in the enterprise world), we could should be in for one hell of a ride come the Agena derivatives!
  8. Guest-16
    Guest-16 Guest
    The press release just mentions Opterons, but Phenoms should be around the same time. Either/Or, they are both Barcelona and it will directly compete with Intel's Quad Cores.
    On die memory for Intel isn't expect until Nehalem next summer.
  9. KMS-oul
    KMS-oul You think you know me.
    1 Aug 2002
    Cant wait to see these tested and hopefully they will live to the hype. However I'll prob end up getting a Quad core 2 when the price drop happens soon.
  10. -EVRE-
    -EVRE- New Member
    12 May 2004
    NOT everyone runs Intel!:naughty:
  11. Phil Rhodes
    Phil Rhodes Hypernobber
    27 Jul 2006
    I run Premiere and After Effects all the time, both of which are fully multi-threaded.
    Mmmmmm. Bacon.
    Phil
  12. DrFreeze
    DrFreeze New Member
    7 May 2006
    what i want to know is... what will these things end up costing on launch?
    if i can pick up a Q6600 for ~€266 from the 22nd of july, then what will a 2.0 GHz quad core amd cost me in august? The way i figure there is no way AMD can compete on price/performance with intel, even with barcelona. If 2.0 is the best they can do in august, they would have to sell their top end desktop chips for ~$250 for them to come close to being competetive with intel.
    Either way, if they do end up launching at low-low prices, and performance doesnt end up sucking, i might not get a Q6600 and switch back to AMD instead, but im not holding my breath
  13. Buzzons
    21 Jul 2005
    Bindi, dont the current/soon to be done Itaniums have onboard memory controllers? Also, does Nahlem actuall conform to the 45nm shrink / 8 cores etc?
  14. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    I make no speculations for or against it - as the men over at XS says - one thing matters, performance. If it gets asshandled, then it'll be a laughing stock like the HD2900s. If it dominates, than this will be just like when the Core 2's crashed the AMD64 scene.
  15. pumpman
    pumpman New Member
    7 Jul 2004
    it is supposed to be more energy efficient though and cooler than c2d which in business enviroment would be good and green too
  16. EQC
    EQC New Member
    23 Mar 2006
    you're not losing it...i remember that rumor too. I think, though, soon after the rumor surfaced, AMD made a statement saying that it was false.
  17. Fiber4now
    Fiber4now Don't feed the trolls
    28 Jan 2007
    I believe you are speaking of reverse hyperthreading where some one claimed AMD was working on a process that would allow a fully working logic unit to dump some of the executions to idle logic units. All most the same thing that Intel was doing with Hyperthreading but Intel added logic units to do so.
    What you are describing is fine multithreading where software is written to divide the workload between core equally. fine multithreading such as the Povray test can take advantage of more than one core and the work output scales. Scaling means that instead of doing the work of 100% of the single cores clock cycles dual cores or more can do 200% of the work that a single core can do.
  18. devdevil85
    devdevil85 New Member
    29 Nov 2006
    45nm Phenom sounds like a good jump for me......cause I've got 90nm right now.... man do I love Moore's Law!
Tags: Add Tags
