Graphics AMD R290X GPU - Titan Killer
Discussion in 'Hardware' started by Neogumbercules, 23 Sep 2013.
  1. Sheiken
    Sheiken Wat?
    9 Jan 2005
    It is not that good a find! check the last page of the thread:sigh:
  2. Lassar
    Lassar Lean Mean Fighting Machine !
    16 Jun 2009
    Does mantle work on all the AMD range or just the new R9 cards?
  3. debs3759
    debs3759 Was that a warranty I just broke?
    10 Oct 2011
    Mantle will work with all GCN cards if you have an up to date driver.
  4. AlienwareAndy
    AlienwareAndy What's a Dremel?
    7 Dec 2009
    Any with GCN? or whatever that is.
  5. rollo
    rollo Modder
    16 May 2008
    Assumption is 7 series and above, till AMD confirms this its just guess work though. But not all 7 series Gpu are gcn. 7950 and above will likely be fine. Everything below and I'd have my douts.
  6. Lassar
    16 Jun 2009
    Im an idiot... whats GCN
    I was thinking of getting a 290x..... is it overkill for 1680x1050?
  7. Parge
    16 Jul 2010
    Graphics Core Next. Its just what AMD call their current GPU architecture.
  8. Parge
    16 Jul 2010
    And..... YES. Definitely.
  9. Lassar
    16 Jun 2009
    Have the 580GTX lightning at the moment....... Maybe I should be investing in a better monitor 1st? or perhaps a 280x.... meh.
  10. Parge
    16 Jul 2010
    The two should really be bought hand in hand. No point in buying a better monitor on its own because your GPU will struggle, no point in buying a new GPU on its own because its total overkill. Or at least that's how I reasoned it.
  11. Lassar
    16 Jun 2009
    I was thinking I would get the card 1st and maybe the monitor afterwards... I like to play with all the eye candy on... even at 1680x1050 :D
  12. MrDomRocks
    MrDomRocks Modder
    5 Sep 2011
    Its all down to budget. Dependant on what you are currently gaming at resolution wise. 1080p I hope.
    Regretting my 670 sidegrade earlier in the year. Though I think it will suit my needs for awhile.
    Sent from my GT-I9100 using Tapatalk
  13. Lassar
    16 Jun 2009
    No not 1080p mate. Screen does not support it. Samsung SyncMaster 2232bw.
  14. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    I upgraded from the Samsung 2232bw to a Dell U2412M earlier this year and the difference between the two screens is absolutely incredible - the Dell utterly wipes the floor with the Samsung.
    In my opinion, you'd be better off upgrading just your monitor rather than just your GPU - your current card is still really capable, and it's just overkill going for a better GPU at 1680 x 1050.
  15. Lassar
    16 Jun 2009
    *edit* Im starting another thread sorry for hijacking this one :(*
  16. GeorgeK
    18 Sep 2010
    Thought I'd answer that - the U2412M is 1920x1200 which is actually slightly higher resolution than "Full HD" which is 1920x1080 (the 1080 bit is where 1080p comes from in TV shops etc). Apart from the higher resolution, the main difference between the two monitors is that the Samsung uses a TN panel and the Dell uses an IPS panel (different technologies) and so the Dell will have better colours and viewing angles etc.
  17. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    My GTX780 goes back this week. So i have a choice of the 7990, 7970,2 x 280x or the 290x. damn decisions decisions
  18. Teelzebub
    27 Nov 2009
    That's the problem being as old as you are Kov by the time you think about the last option you've forgotten what the others was :p
    G0UDG likes this.
  19. Kovoet
    26 Aug 2009
    You freggin nutcase lol
    G0UDG likes this.
  20. heir flick
    heir flick Minimodder
    2 Feb 2007
    290x too hot and loud, 7990 cheap but ive read they suffer from coil whine, 7970 or 280x crossfire would be my choice, i have 2 7970's and thinking about changing to 280's because my 70's have reference coolers, proberly a bit silly i know but what can you do when you get these ideas in your head
