Hardware AMD Radeon 7970 3GB GHz Edition Review
Discussion in 'Article Discussion' started by Baz, 22 Jun 2012.
  1. Harlequin
    Harlequin Modder
    4 Jun 2004
  2. The_Crapman
    The_Crapman Don't phone it's just for fun. Staff
    5 Dec 2011
    Ah. I thought the jetstream was also overclock. Silly me!:rolleyes:
  3. xxxsonic1971
    xxxsonic1971 W.O.T xxxsonic1971
    5 Dec 2010
    nice1 AMD!!!! maybe see some bargain basement 680's soon?
  4. MjFrosty
    MjFrosty What's a Dremel?
    3 Aug 2011
    :wallbash:
  5. ssj12
    ssj12 Minimodder
    12 Sep 2007
    the entire issue with the GTX680 ia 2GBs of ram. If it has 3GBs those numbers would be different.
  6. Elton
    23 Jan 2009
    Sadly they could not make a HD7990 (like the 4890) and have it be clocked much higher. The limits of silicon approaches.
  7. David
    7 Apr 2009
    How do you figure that?
    CPC tested a 2Gb 680 alongside a 4Gb model and saw no appreciable difference between the two.
  8. Elton
    23 Jan 2009
    Multi monitor gaming I believe.
  9. Valinor
    Valinor What's a Dremel?
    30 Oct 2010
    I think it was more the limited bandwidth than the actual amount of memory.
  10. Elton
    23 Jan 2009
    Increasing RAM size would do nothing, it would either take a wider bus or faster RAM.
    An increase in RAM size then would only be effective if the games tested used a higher resolution. Hence my multi-monitor gaming remark.
  11. rollo
    rollo Modder
    16 May 2008
    680 2gb is not memory restricted outside of multi moniter resolutions. been proven on this forum by alot of different people
    7970 uses more memory cause its there to use but games dont require it.
  12. silky
    silky What's a Dremel?
    25 May 2012
    For those who want to compare with older cards, there is a website somewhere which lets you compare anything with anything. Unfortunately I lost the link :(
  13. Skulldragon
    Skulldragon What's a Dremel?
    20 Nov 2011
    Do you mean this website?: http://www.hwcompare.com/
    It's a pretty useful resource, however, unless there are actual game benchmark comparisons for the two cards you are trying to compare, it can be difficult to know how the theoretical differences translate into in-game performance
  14. Baz
    Baz I work for Corsair
    13 Jan 2005
    Just repeating what others have said; 4GB versions of the 680 are no faster than 2GB versions, even at 5,760 x 1080 (three-screen surround). It's the bus-size that's the limiting factor, something that using higher density chips do not help.
  15. Action_Parsnip
    Action_Parsnip What's a Dremel?
    3 Apr 2009
    I too think that bandwidth is an issue with the 680. The ratio of compute to bandwidth has dropped HUGELY compared to the GTX 580, for starters.
    Also if you look at power consumption on 680 SLI in multimonitor situations Battlefield 3 , despite being the most graphically demanding current title, does not draw the most at the wall. It is also known to be HIGHLY memory bandwidth sensitive.** I would theorise that the higher turbo states do not engage in this game at this resolution due to the GPUs not having enough data on hand to warrant maximum clock speeds.
    http://hardocp.com/article/2012/03/28/nvidia_kepler_geforce_gtx_680_sli_video_card_review/8
    In this test Deus Ex. records the highest power consumption number I would guess due to it being both the *least* bandwidth sensitive title and best matching it's coding to the architecture of the GTX 680 GPU.
    ** See Battlefield 3 test results run with the VERY bandwidth limited Gefore GT 640 GDDR3
    http://www.anandtech.com/show/5969/zotac-geforce-gt-640-review-/10
  16. xxxsonic1971
    5 Dec 2010
    the 3gb 7970 is the sweet spot, most powerful gpu on the planet!!!
  17. silky
    25 May 2012
    Yeah thats the link thanks :) I bookmarked it now.
  18. Fizzl
    Fizzl What's a Dremel?
    9 Jun 2009
    Some data on how two of these perform on 6048*1080 (because who plays without bezel correction?) vs the 690 would be nice. After all you could get two for the price of a 690.
