Hardware AMD Radeon HD 6990 4GB Review
Discussion in 'Article Discussion' started by arcticstoat, 8 Mar 2011.
  1. thelaw
    thelaw What's a Dremel?
    10 Sep 2010
    Just far far far too expensive to be practical at the moment and i dont think it can justify its price....its almost the half the build cost of a decent gaming pc on its own..
  2. Unknownsock
    Unknownsock What's a Dremel?
    13 Jul 2009
    I can't help but think, use some different games!
    That is defintely a beast of a card, although I still think 2x 6950's re flashed to 6970's is the way to go. Just shy over £400 too.
    Whether i agree with Andrew or not, i can't help but feel the same way with the your current games list.
  3. Glix
    Glix Left Thumb Stick in the mud.
    11 May 2010
    Where's the Crysis bench? :p
    (honestly BT need to increase the number of gaming benchmarks, none of those games really showed much for the card except when the 2 cores bulldozed through 2560x1600 res).
  4. DbD
    DbD Minimodder
    13 Dec 2007
    As the others say it's testing performance not game quality.
    The other thing this would test much better is microstutter - you aren't going to see it if the min frame rate > 60fps, if you max out metro and bring the card to it's knees then you have a much better chance of finding out if it stutters.
  5. Blackmoon181
    Blackmoon181 Geography,Its not just colouring in
    23 Nov 2008
    use ARMA 2 please. I want see that card cry like a little girl when the draw distance is increased !
  6. memeroot
    memeroot aged and experianced
    31 Oct 2009
    whats the point of comparing it to a single card? is it faster/better value than crossfire/sli?
    stupid stupid
  7. Deders
    Deders Modder
    14 Nov 2010
    I'd play it again, once I get a card that can run it with high enough minimum framerates to make it smooth at highest detail with hardware Physx.
    Isn't it the second game to be released with this engine so far?
  8. chris66
    chris66 Minimodder
    10 Jan 2011
    So, is this card classed as a 'single' gpu, like the 580, or is it a duel GPU made to fit a single PCI-E slot?
  9. Deders
    Deders Modder
    14 Nov 2010
    It's a dual GPU, must be early in the morning for you to miss that in the review.
  10. memeroot
    31 Oct 2009
    but not in the comparisons...
    from toms
    "A pair of Radeon HD 6970s sacrifices nothing except space in your case. That combo is faster, quieter, and more effective at dealing with heat. A pair of GeForce GTX 570s would be a great alternative, too."
    though as my 2x 570 setup is STILL not working with sli I shall abstain
  11. chris66
    chris66 Minimodder
    10 Jan 2011
    Oops! you're right, I am an idiot!
    I guess the only other GPU to compare it with, then, is the upcoming 590. Will be interesting...
    (I remember paying £540 for an NVidia 7950 - still going strong in daughter's PC..)
  12. runadumb
    runadumb What's a Dremel?
    20 Jan 2010
    Why's that? My 2x570 Setup is working great. Runs hotter than hell though. Well, the GPU temps are fine but the hot Air it blows out of the case is scary.
    Don't know why Bit-tech hate Sli/CF so much. This is my first dual GPU setup and it's worked great. I need it for the 3 displays, in fact I need more power.
  13. wyx087
    15 Aug 2007
    awesome card, it'd be a hard act to follow, considering nvidia's gtx580 is already pretty power hungry as a single card, and their scaling isn't as good as 6000 series.
    regarding benchmarks, BFBC2 is all that's needed at the moment. all other games feel biased, Dirt2 favours nvidia, Metro favours AMD, but at the end of the day, the competition makes sure all the end user has to do is pick a price range and buy the brand they prefer.
  14. memeroot
    31 Oct 2009
    what kind of sli bridge do you use?
    I'm using a asus flexible on 2 pny cards on an emu Cheesecake board... it just bsod'ths when sli is enabled. .... :-(
  15. runadumb
    20 Jan 2010
    Same setup. I can't remember the model number of my motherboard but it's the ASUS board Bittech used to recommend for core i7 systems. Maybe your powersupply is crapping out?
  16. fingerbob69
    fingerbob69 Minimodder
    5 Jul 2009
    " Most concerning is that AMD says that you void your warranty by using the Antilles Unlocking Switch – this is a ridiculous decision considering that the switch is a standard feature of all cards"
    You might want to point out that this in contravention of UK consumer protection law.
    If this feature of the card is available to consumers to use, put there by the manufacturer for consumers to use it is classed as a standard feature. It forms part of the normal working parameters of the card and is covered by the UK obligatory one year warranty AND any extra covered offered by AMD.
    The manufacturer can't turn around and say "haha ...warranty voided" when the consumer uses a built in standard feature.
  17. Deders
    Deders Modder
    14 Nov 2010
    Try a solid one, i had problems getting the flexi bridge that came with my motherboard to work properly.
  18. bemused
    bemused What's a Dremel?
    9 Jan 2011
    Way too much money I think, £450 is probably my max. for a GPU given how fast they depreciate.
  19. Gresel09
    Gresel09 What's a Dremel?
    7 Mar 2011
    Radeon HD 6990 is an awesome graphics card. I want to buy this but the price is really high. I'll just when the price goes low so that I can afford. I'm not really a heavy gamer, and now I'm still using my GF 9500GT card.:D
  20. Crowder10
    Crowder10 What's a Dremel?
    12 Jul 2010
Tags: Add Tags
