Hardware AMD Radeon HD 7750 1GB Review
Discussion in 'Article Discussion' started by brumgrunt, 15 Feb 2012.
  1. brumgrunt
    brumgrunt What's a Dremel?
    16 Dec 2011
  2. xxxsonic1971
    xxxsonic1971 W.O.T xxxsonic1971
    5 Dec 2010
    ''though, it's a bit of a let down when we'd hoped it might offer performance close to the HD 6850 1GB for a lot less. Sadly this isn't the case'' - the 6850 is a far better card, how can you compare the two?
  3. docodine
    docodine killed a guy once
    10 Feb 2007
    ...they were hoping that the low-midrange new gen cards would beat the high-midrange previous gen cards, not unreasonable
  4. N17 dizzi
    N17 dizzi Multimodder
    23 Mar 2011
    The two top single screen resolutions + maximum settings. Is that an appropriate benchmark for a low end card?
  5. Baz
    Baz I work for Corsair
    13 Jan 2005
    At time of writing the £6850 was £10-£15 more. Seems a fair comparison to me.
    We test all graphics cards equally, regardless of their place in the roster, otherwise we end up comparing apples to oranges; this way you get a clear idea of performance on offer right up the scale. No two systems will ever be the same; consider it more a representative demonstration of performance . 1080p is the becoming the standard for displays, so of course we tested that; 2560 x 1600 is again, just a standard test we perform. We're not going to go back to 1280 x 1024 just for low end reviews.
  6. Baz
    13 Jan 2005
    Indeed; we'd hoped that 7770 and 7750 would match/surpass 6870 and 6850. What with the improvements in production process and the more efficient Southern Islands architecture, this didn't seem out of the question, but obviously AMD has decided to add a bit of juice to the HD 5770 and make it more power efficient. 20% extra performance is great and all, but that's 20% more than a card released 29 months ago!
    What really interested me now is
    HD 7950 3GB - £350
    HD 7770 - £100 (although today we're seeing prices of around £120!)
    That's a huge £250 price gap for the 7800 series to fill, wouldn't you agree?
  7. mat0tam
    mat0tam Mr I Dont Know What I Want
    1 Sep 2011
    Totally agree. Interesting reading
  8. N17 dizzi
    23 Mar 2011
    Feels more 'too much work to test as is appropriate' than some self righteous stance on 'all graphics cards should be tested as equals'.
    They're not equals, in some cases they're, apples and oranges.
    A £600 card vs a £100 card. Two completely different ends of the market, two completely different types of user.
    The sort of user in for a £80 - £100 card is going to take 1 look at your graph with 18 different cards on, see the 7750 and other low end affordable models at the bottom with awful, and in some cases, unplayable performance then go back to the Xbox happy in the knowledge that PC gaming is expensively not worth it.
    But you're the experts. What do I know.
  9. misterd77
    misterd77 What's a Dremel?
    18 Apr 2011
    as a budget card, it should have been tested at lower resolutions, I own a 5670, which cost £45, so it would have been interesting to see its performance at these lower resultions, a budget gamer like me isnt interested in 1080p res, as I have a 19 inch widescreen, at a res of 1248 x 1024, and I think this card is aimed directly at gamers like me, once again, I have to go elsewhere to find the information I need, also, there is no mention of apu dual graphics performance, which I think this card is really made for, my 5670 1gb ( 35 fps in Skyrim at medium setting) performs the job well enough that it wont be untill the new apu's are released at the end of the yr, that I will be considering a new build, by then, its price should have dropped, but, for the moment, it seems a tad overpriced, and only a small step up from previous amd budget cards.
  10. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
    awww diddums, is all I have to say on this
  11. Farfalho
    Farfalho Minimodder
    27 Nov 2009
  12. mrbungle
    20 Sep 2004
    ati needs to pull its thumb out, for several generations its mid range cards have been TERRIBLE.
    £100 for this? Seriously??????
  13. schmidtbag
    schmidtbag What's a Dremel?
    30 Jul 2010
    any idea if this can go in crossfire with the 5700 or 6700 series? those 2 generations were compatible. i'm assuming this won't work, since its a new architecture but you never know.
    i think if the price dropped a little it'd be more reasonable, but i don't think this is a bad card. i'm personally impressed that the 7750 can operate without the extra power while performing like a 6770. also i like their small size - makes it easy to do 4-way crossfire.
  14. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    How was the HD5770 terrible?
  15. N17 dizzi
    23 Mar 2011
    Is that regarding the card or the some of us that would like to have seen more reasonable settings used for the tests? :)
  16. mrbungle
    20 Sep 2004
    Serious?
    The hd5770 is barely faster than a old 4870 and wasn't particularly cheap new. It doesnt even retain much value even 2nd hand on the forum which is a sign its pony.
  17. Skulldragon
    Skulldragon What's a Dremel?
    20 Nov 2011
    If the card doesn't get tested at lower resolutions, then an extra section for each game telling us what details settings the card can play the games at 1920x1080 and 2560x1600 at would be quite useful. Also, is this the most powerful graphics card around which doesn't require any additional power than what it gets through the PCI-E slot?
  18. SexyHyde
    SexyHyde Minimodder
    24 Jul 2009
    instead of doing the 2560x1600 & 1920x1080 for everything, you should do 1080p for everything, so you can see performance against everything AND an appropriate resolution/settings for the card involved, so you can see how it performs for the intended use. This card might be able to play games at high settings @ 1680x1050 which i'm guessing is what its aimed for (oh wait it is - i just checked it somewhere else and they rated it highly). Now i know you guys are serious about what you do, but i don't think you are approaching these cards appropriately. This card / range doesn't even interest me as i'm a 1080p gamer with a decent set up, but i found the review totally missed the point of the card, it was written and tested as though it was a better card. What it offers felt dismissed in the review, evident in the score.
  19. d1ck0
    d1ck0 What's a Dremel?
    1 Dec 2009
    Totally agree , I think bit-tech should do a poll of the average screen resolution we run , personally I run at 1680 * 1050 with a Asus EAH5870 which is MORE than adequate to see all eye candy in games ! :).
  20. Baz
    13 Jan 2005
    This card is the same price as the HD 6850. It is up to 30 per cent slower than that card in performance tests. There is no way this can be seen as 'good' no matter what resolutions you test at, unless your PSU lacks a 6-pin PCI-E connector. Bit-tech's focus is on the higher end; its what you, our readers have told us you're more interested in reading about, and its what the traffic stats demonstrate too. It's why you usually won't see us testing the super-low end GPUs (in fact, for GPUs, £80 is usually our lower limit), £40 value motherboards or £15 tin-can cases, and it's why we haven't tested at 1,680 x 1,050.
Tags: Add Tags
