Hardware AMD Radeon HD 7850 2GB Review
Discussion in 'Article Discussion' started by brumgrunt, 5 Mar 2012.
  1. Baz
    Baz I work for Corsair
    13 Jan 2005
    I'm aware we've ignored you folders, so next month I'll hopefully be doing some F@H and compute performance on the 7-series cards. Stay tuned!
    Regarding CrossFire numbers. Our current test rig doesn't actually support CrossFire. D'oh. We'll be replacing it when Ivybridge and Z77 come out, so expect some CrossFire and SLI performance investigations once we hit the quiet summer months.
  2. dunx
    dunx ITX is where it's at !
    1 Sep 2010
    Thanks !
  3. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    Damn no one told my wife's HD4870 this.
    It easily manages mid 40's at a mixture of high and medium settings.
    Incidently barring the resolution difference it looks no different to BF3 running on my HD7970.....
  4. MeddlE
    MeddlE Norwegian Blue
    23 May 2011
    Really? My 4890 begs to differ. Do you actually have one or are you pulling your info from somewhere unsavoury?
  5. greigaitken
    greigaitken Minimodder
    26 Aug 2009
    Isn't it time bit-tech updated their fps graphs. techreports graphs are leading the way - showing you how jerky that fps rate is over time.
  6. johnnyboy700
    johnnyboy700 Minimodder
    27 May 2007
    Only extra thing I need to know to convice me to buy one is what are the noise levels like?
  7. GiantKiwi
    GiantKiwi What's a Dremel?
    6 Jan 2011
    Really? I can tell the difference quite easily, its effectively the difference between playing on medium, compared to ultra.
  8. T2I3M
    T2I3M Minimodder
    13 Mar 2010
    Me too bro. Hoping the 7870 comes in around £250, otherwise a 7850 will have to do :p
  9. manowarrior
    manowarrior What's a Dremel?
    9 Mar 2011
    I have that same card, however I game at 1080p and have held off getting BF3 untill I get my next GFX card.
    The 4890 has been a great card tho and was a worthy replacement for my 8800GT 27 months ago now,
    I remember at the time I could have spent more for a card with DX11 capabilities, but I went for pure FPS/price, and as I love Windows XP and stilll use it, happy to have let DX11 pass me by tbh.
    Will be nice to finally play BF3 & Crysis 2 DX11/HD Textures once I can finally afford a new card,
    Maybe, just maybe I'll try to hold off, or just be skint untill after the next generation of consoles have been released then better them with my GFX card, that card could last for years.
    The new AMD 78xx cards look nice but I'll wait to see what Nvidia has planed then go for the best bang for buck as always (if I have the cash).
  10. xaser04
    27 Jun 2008
    :confused: Yes, otherwise I wouldn't have made the statement.
    To clarify playing at medium / high on my wife's HD4870 looks basically the same as playing at medium / high on my HD7970 minus the massive resolution/speed difference.
    Perhaps I could tell the difference if I screenshotted it and then looked at the images in detail but I have no time for that - well that and it would be a bit difficult given that one will be at 3560x1920 and the other 1680x1050...
  11. Rich_13
    Rich_13 What's a Dremel?
    12 Feb 2003
    Would actually kill for a single slot solution!!! Praying one of the vendors does it.
  12. Deeon
    Deeon What's a Dremel?
    8 Oct 2007
    To wait for HD 7850 and hope it will cost about 200€... or get GF GTX560Ti OCed version for 200€ right now?
  13. Deeon
    8 Oct 2007
    That is 200 Euros.
  14. warmbit
    warmbit What's a Dremel?
    27 Mar 2012
    Hey,
    Here is the link to an interesting overview performance 7870 and 7850 of 5 Web sites competing Nvidia cards - GTX580 and GTX570 and penalties of the previous generation AMD - 6970 and 6950.
    Analysis of the results of the Radeon 7870 and 7850 in 12 games and 5 resolutions:
    http://translate.google.pl/translat...03/analiza-wynikow-radeona-7870-i-7850-w.html
    You will know the relationship between average interest rates these cards and you will find out in which graphics card is better in the game and resolution.
Tags: Add Tags
